Hopefully Yance can get to the GoPro footage taken from this project sometime in the future as it captured then entire process from start to beginning.
Here's the tape I used for all the raised body lines and there were a lot of them...
What speed setting are you guys using with the Trizact 1500 and the 3000 on the DA.
Keep in mind that the Trizact 1500 Clear Coat Sanding Disc (which is identical to the Meguiar's 1500 sanding disc except for color) is different than from the Trizact 3000 and 5000 discs in that the former is a sanding disc and the latter two are finishing discs.
The 1500 sanding disc is going to cut much faster than the finishing discs, and from experience, I have come to find that 3 is the best speed to run them at.
The finishing discs, on the other hand, work best at speed 4.
At this very moment I'm preparing to do some damp sanding of my own with these very same discs. Just finished getting everything taped off...
2013 Honda Accord Touring - Crystal Black Pearl/Black
Re: Time-Lapse Video: Wetsand, Cut and Buff 1964 Malibu
What a turnarround!!!
mike can u point me to a walktrough on the correct way of wet sanding and how to choose the correct paper? did a search for it but did not found something solid as youre postings are.
WOW! i dont get how all of those didnt turned up on my searches , guess i did not dig deep enough
Mike you are the man!
They are all on my article list under wetsanding and the link to my article list is in my Signature Line. With almost 40,000 posts it's pretty easy to find my article list.
If you have any specific questions, please post them...
