Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Aug 2015
    74
    Question Can't clean AIO from pads?!?
    Is there any way to clean AIO (and LSP) pads after use? I've been soaking the pads in McKee's 37 Pad Rejuvenator, but that only works to a point. Because products like McKee's 370 360 and Blackfire One Step have a sealant in them, the M37 PR solution doesn't seem to get the sealant out very well. Is there another method or chemical you all use to clean those pads? Dawn dishwashing soap maybe? Thanks for suggestions!
    Sep 2015
    2,173
    Re: Can't clean AIO from pads?!?
    McKees 360, while it's an awesome product, stained every pad I used it with. I finally gave up trying to get them completely clean, and now those pads are dedicated for 360.
  3. Thanks SwedishRider thanked for this post
    Likes Coopers ST liked this post
  4. #3
    Super Member LEDetailing's Avatar
    Jan 2016
    Wisconsin
    1,729
    Quote Originally Posted by briarpatch View Post
    I do the same. I had the same issue with HD Speed and pads staining. Clean them until you can’t see any product coming out, then dedicate those pads to AIO use. I hate that I probably have 50-60 pads, but that is just the price of being prepared
  5. #4
    Super Member Belo's Avatar
    Jul 2014
    Rochester, NY
    492
    same. but the stains don't bother me or lead me to believe they're no longer good. I still clean them with xmt pad cleaner and brush.
    2009 Pontiac G8GT
    2015 Ford Explorer Limited
    2019 Chevy Silverado RST Z71
  6. Likes Eldorado2k liked this post
  7. #5
    Super Member ski2's Avatar
    Dec 2011
    Southwest PA
    1,826
    After soaking them in APC I clean them with LA Awesome Orange Degreaser from the Dollar Store. Doesn't get all the stain out, but gets the LSP and AIO out of the pad.
  8. Thanks SwedishRider thanked for this post
  9. #6
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,772
    Mckee's Polishing Pad Cleaner works wonders.
    It even got out some older stains from HD Speed on my LC flats & ThinPros.
  10. #7
    Aug 2015
    74
    I'm curious how you use it. Do you let the gunk dry into the pads and then just use M37 Polishing Pad Cleaner on the surface and then scrub?
    I'm thinking about mixing up a bucket of M37 Pad Rejuvenator and tossing each spent pad into the solution right after using them (while still wet with AIO product). Then spray them with M37 Pad Cleaner as I take them (soaked) out of the solution and scrub them with a brush to clean. Does that sound like a good plan?
  11. #8
    Jan 2014
    Eastern L.I. NY
    10,772
    I do not let the product dry into the pads.
    I'm sure your idea would work.
    I'm just a hobbyist, so when I am done with a pad, (still wet with product) I spray the McKee's PPC liberally onto the pad, then scrub it pretty good with my pad cleaning brush. (I have the Griot's brush) I'll let it sit a couple minutes, then go wash it out in the sink.
    I am very impressed with how well it cleans my pads.
  12. Thanks SwedishRider thanked for this post
    Likes SwedishRider liked this post
  13. #9
    Sep 2017
    Sweden
    3,022
    I have testing to spray some 50% ipa on the pad so it's just get a little saturated. Massage it in the pad and wait a couple of minutes and then in the bucket with the pad cleaner solution. The AIO I used was a carnuaba wax based one. And think I got it to be clean. It looked and feeled clean when rinsed out in the sink. Will see how the pads works next time I use them.
  14. #10
    Super Member sudsmobile's Avatar
    Jan 2018
    IE, SoCal
    970
    HD Speed stains like hell but it doesn't ruin the pad. The pad works just as good the next time you use it. We use a 4 gallon bucket filled with warm water and a packet of Snappy Clean and let them soak at the job sight and overnight.
  1. Polishing pads...how clean is clean enough??
    By jmeyers278 in forum Auto Detailing 101
    Last Post: 11-23-2017, 09:56 AM
  2. how to clean foam applicator pads and microfiber pads
    Last Post: 05-24-2012, 06:33 PM
  3. How often to clean Pads?
    By jerlands in forum Auto Detailing 101
    Last Post: 01-09-2012, 06:03 PM
  4. How to clean pads?
    By RoyalBlUE08 in forum Wool & Foam Buffing Pads
    Last Post: 09-20-2011, 12:33 PM
  5. How to clean my pads?
    By NiSyam in forum Auto Detailing 101
    Last Post: 05-11-2010, 12:06 PM
