paint coating hype
not understanding all the hype on the paint coatings anybrand. they all tell you to mist it on a very miniscule amount is needed for protection just not buying it help convince me any long term reviews anything on these over the long haul science of it all may be there but I need proof .
Re: paint coating hype
It's similar to the same hype of where: Only a very miniscule amount (a few millionths of an inch)
of other Last Step Products (LSP's)...such as Waxes and Sealants...would be applied on
a vehicle's surfaces for protection, as a sacrificial barrier would so equate.
If a person doesn't believe in scientific proof...how, then:
are they to accept empirical findings as the real truth? ~Bob
How's that for visual reply?
I'm sure others will chime in with their thoughts...
Mike...."especially what's in the works..." now what's going on???
WildWilly1, just curious, what products are you using right now? Are you a noob to detailing in general? The reason I ask is because maybe you need to work your way up. After using a nuba maybe a "hybrid" is in order, maybe a sealant, also you might wanna try a WOWA product (wipe on walk away) like Black Fire Crystal Seal and then step up to the latest and greatest, paint coatings.
I've tried DP paint coating recently, over a month ago and I can honestly tell you the stuff is for real! It really does feel differently, the look is "candy" and yes, it really is that easy to apply. When your used to "wax on, wax off" and getting "Popeye arms" getting the stuff off, the newer tech might make you roll your eyes but rest assured these new products are AWESOME, ALL OF THEM!
2022 Elantra N Cyber Gray
i do not do this for a living but i have been detailing cars for some while just not up on the latest and greatest products. the last lsp i used besides a wax was blackfire wet diamond loved it. it was used on a black hummer h2 i had after proper paint correction. i currently have a black audi a8 i am getting everything together to do the paint correction and would like to get a great coating wax sealant whatever it may be to protect the paint when i am done. my only problem now is that i live in ky temps now are in the upper 30s mid 40s for highs will be this way until march too cold for a coating correct. what would be the absolute best coating to use for looks and durability thx
Where the rubber meets the road...
Here's the deal though... as great as the results look in all these detailing projects we did here at Autogeek, and as beautiful as the final results look... the end-results are still dependent upon doing the proper prep work.
Then, after doing the proper prep work you really can create clear, glassy looking paint and the coatings themselves do last longer than traditional car waxes and synthetic paint sealants.
After applying the coating you still must carefully wash your car and maintain the finish if you want to maintain the results. Just because you apply any coating to your car's paint this does not automatically give you the freedom to start running your car through a automatic car wash or even wash it yourself haphazardly as you will diminish the appearance.
I love coatings and the way they can protect the cars paint but one thing I feel that gets over looked is that these coatings are not bullet proof nor scratch proof.
As Mike has already stated Proper Washing is key to keeping yout coatong scratch and defect free. You should still be doing a 2 BM for washing with grit guards and drying with the blotting method and good WW towels or a filtered air blower. You will want to take all the same pre-cautionary measures as you would with any other form of LSP.
You will always want to remove and bird bomb, standing water, or anything else that would etch into the clear coat.
Some of the coatings like the DP and Black Label coatings had the properties that allow you to use a sealant and or a wax ontop of the coating. Others like Opti-Coat, while you can still place a sealant or a wax on top of it wont allow the wax or sealant to remain on the surface for very long.
Coatings are great but they aren't for everyone so you just have to decide what you like. If you do go with them the as stated prep is key and post coating wases will keep it looking great.
what about the temperature for application
I wrote this a few years ago before coatings were the real deal but the recommendations and info is just as accurate today as it was when I wrote it.
What temperature ranges are best for applying compounds, polishes, waxes and paint sealants
Here's the main point if you don't want to click over and read the entire article...
Most premium quality car detailing products will work easily within a much broader temperature range, such as, 50 degrees to 90 degrees Fahrenheit but optimum results are when you're working in a range of 60 degrees to 80 degrees.
Information overload! I losing it over here! Lol
Last Post: 07-13-2020, 01:54 PM
Last Post: 09-16-2017, 07:51 PM
By expdetailing in forum Hot topics & Frequently Asked Questions
Last Post: 01-16-2015, 11:39 AM
By fredcandetail in forum Auto Detailing 101
Last Post: 03-14-2011, 08:23 AM
By THENIZZZEIL in forum Off-Topic
Last Post: 10-22-2007, 01:53 AM
