Just found this site and have been reading up. I do have a couple questions that I'm hoping to get some professional advice.
I recently received my car back from body shop. Car was stripped to bare metal, some minor body work and fresh paint/clear. Shop did a great job on body, panels and paint except that i'm finding several small areas with sanding marks.
Question 1 - what should i use to remove sanding marks (by hand)?
Question 2 - After removing sanding marks - what product(s) should I use... sealant? wax? both? Do you suggest using machine or hand application?
Omg,a clean 1968-69 pontiac firebird,looks good already
Yo mackdaddy - close... she's a '67 and thanks.
Originally Posted by dublifecrisis
I would say either go back to the body shop and demand they fix the issue OR invest in a machine polisher and do it yourself.
I say get your own polisher. You're in the right place to keep that beauty looking its best.
Welcome!
dublife - i have the portercable 7424 but have only used it to wax my boat. Would you use the ML105 with the portercable? taking the car back to the shop is not an option. Our 'relationship' did not end well. It's like the shop was rushing to finish the job b/c they were 6 mos late with delivery and I was bustin their balls to finish.
Originally Posted by richy
It really depends on how deep the sanding marks are...I would definitely go back to hte shop...that's not acceptable.
Richy - marks do not appear to be deep and are in locations that are not very visable. It's just that I'll know they're there.
The M105 works really well by hand to remove just about any kind of below surface defects, you just have to put a little passion behind the pad...
In the hood of the 1969 El Camino in the picture above, I used a microfiber applicator pad but you can also use foam.
Afterwards you want to either polish with a less aggressive product or apply a wax or paint sealant. Because that's a brand new paint job you should probably use a finishing wax or sealant.
Here's the actual picture. I noticed you uploaded a picture to your gallery, once you do that all you have to do is "insert" the code to make a picture show up,
