Re: New Guy lookin for advice
Just to chime in...
The M105 works really well by hand to remove just about any kind of below surface defects, you just have to put a little passion behind the pad...
In the hood of the 1969 El Camino in the picture above, I used a microfiber applicator pad but you can also use foam.
Afterwards you want to either polish with a less aggressive product or apply a wax or paint sealant. Because that's a brand new paint job you should probably use a finishing wax or sealant.
How old is the paint?
Hang on and I'll get you a link...
Mike - I will try the M105 with an applicator.
Final paint was completed Mid August '09 - I took delivery Mid Sept and have done nothing to the paint. I've been letting it cure all winter.
Wow - that's a lot of good info there - and a bit overwhelming.
Would you suggest sticking with only a finishing sealant or only a finishing wax? I saw the "Forum Favorite package" suggests using a sealant then wax over it.
Thanks for all the help.
Have you inspected the paint in bright, overhead sun for swirls?
Sad to say, the norm for sanding and buffing from body shops is Swirl City, we call them Horror Stories here in the forum world and this can apply to both sanding and buffing work done at body shops or detailing work done at Dealerships and Detail shops.
The usually high-end cut and buff job, (which isn't really high-end in our world), includes sanding, compounding, polishing and hand applied glaze. The Glaze is water soluble and after one or two washes it's gone and the swirls show up.
Then out of desperation and frustration you'll see people join forums like this, share their horror story and ask for help to figure out how to remove the swirls on their own. The reason for this is because,
"If the folks at the body shop, dealership or detail shop couldn't do it right the first time they won't be able to do it right the second time and every time they work on your car you'll have less and less precious paint or film-build left on your car. (The stuff you just paid to have sprayed onto the car).
But I digress... let's hope you're one of the lucky ones...
I'm putting Fusion over M21 on this car as we speak, after sanding and then putting the paint through a multiple-step machine polishing process.
After sanding, compounding/RB, polishing/RB, polishing/DA (before wipe-off of last application of M205
With M21 Synthetic Sealant
After wiping off M21
Next... Füzion
Mike - I'm satisfied with the paint - with the exception of the sanding marks and a couple dings. I have gone over this thing from top to bottom and there are definitely no swirls. This is how I found the sanding marks (under rocker panels, few around tail light assembly, under front apron). The areas with the marks are small and look like they missed them with the machine.
That el camino looks awesome! You've given me a lot to read up on and consider. I really appreciate your assistance.
Mike - that's great... I have my marching orders. While I'm reading up on your links and figuring out what ill use for a sealant or wax - I'm going to grab some of the CCS pads you mentioned and the M105 and work on those trouble spots.
I really appreciate the help. I'll let you know how I do with the M105.
Thanks again.
Good luck and have fun and thanks for sharing your beautiful car with our forum members.
Firechickens, err I mean Firebirds are very cool muscle cars that get respect wherever you take one.
Thanks Mike... it's been a long haul to get this Firechicken to where it is now and with everyone's info on this site, I feel more confident in the process and products to use to finally get on the road this spring.
Thanks again!
By Booki in forum Wet-Sanding, Cutting & Buffing
Last Post: 03-05-2019, 03:09 PM
Last Post: 01-08-2019, 09:56 AM
By goblue4016 in forum Wet-Sanding, Cutting & Buffing
Last Post: 10-08-2015, 12:58 PM
By jacket in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 10-19-2013, 12:59 AM
By Mary Steinborn in forum Wet-Sanding, Cutting & Buffing
Last Post: 05-27-2010, 05:15 PM
