I had read about this tip months ago and finally decided to put it into action today. It worked pretty good for V1.1 and thinking about version 2.0.
I used some left over pressure treated 2x6's and cut them to 22 in. I used my Dakota tires as the worst case. After using 1 time, they should be longer but I was trying to keep the weight down. They could use an end stop (like car ramps so you know when you are in position) and also tethered so you can pull them out easily.
I did not finish until it was dark so no after pics.
