Dislikes: 0
Junior Member
Removing minor paint transfers
I have the typical minor paint transfers from door dings an the Jeep. I did a search but couldn't find much on this alone. I want to remove them with out going to deep into the clearcoat. Lookinf for the safest method to remove them. These are just minor paint transfers no dents. I do have Meguiars 105 & 205. Should I try 205 first by hand or another product? Thanks guys, Dave
Super Member
Re: Removing minor paint transfers
Depending on how bad it is either 105 or 205 "should" fix it. I wouldn't even bother doing it by hand
Super Member
Even a clay bar might be able to take care of it; if not 105 or 205 should do the trick.
Junior Member
I tried the clay bar until rain stopped me. It didn't do any good. I'll try the 105 & 205 combo. I remember as a kid (long time ago) the trick was to use toothpaste. I wonder now how much we did more damage then helped.
Super Member
I had some paint transfer that was thicker than most, no underlying damage. I worked my way up to a Mr. Clean Magic Eraser with clay lube. Removed the transfer slicker n snot leaving a bit of marring that 105/205 fixed up good as new. YMMV.
TL
Similar Threads
By 69chevymaro in forum How to Videos
Last Post: 05-24-2019, 08:12 PM
By brians98ss in forum Auto Detailing 101
Last Post: 06-18-2016, 07:05 PM
By tguil in forum Wet-Sanding, Cutting & Buffing
Last Post: 04-23-2013, 02:18 PM
By Yoshi94 in forum Auto Detailing 101
Last Post: 04-21-2013, 10:23 AM
By purplenurple in forum Auto Detailing 101
Last Post: 06-21-2007, 01:58 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
