Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
  1. #1151
    Junior Member barkeater's Avatar
    Join Date
    Mar 2013
    Location
    Buffalo NY USA
    Posts
    61
    Post Thanks / Like
    Re: Headlight Restoration-new UV sealant idea
    OK, doesn't seem to be much activity on this thread as there once was but I am going to do my best to document my project if nothing more than for my own sake.
    I had a chance to remove the spar coating from the "bad" headlight and polish it in preparation for another go with the spar/ms mix. This time I purchased a can of liquid spar as referenced in the beginning of the thread instead of trying to use the spray. don't know if this is going to make any difference. Also, using new, clean glass containers to mix up the spar/ms. Finally, bought the blue scott towels.
    This morning had a chance to give it a go. Prep'd the surface by wiping down with ipa. Mixed up my spar/ms to a 7:3 ratio. Folded up my scott towel, dipped in and began to apply.
    First thing I noticed is that the coating is much more striated than when I previously used the foam brush. My understanding is that these disappear as the coating settles. Striations aside, I was not happy with the evenness of the coating. So much so I wiped it off with scott towel and ms. Just didn't look right.
    I still had a clean foam brush so I mixed up some more spar/ms mix and reapplied using the foam brush. The coating was very even and no sign of the milky areas which appeared in my previous attempt. I looked it over to make sure I didn't miss any areas and after a minute or two considered it a coating I was willing to let dry. I post up some pics tomorrow.
  2. #1152
    Junior Member
    Join Date
    Jul 2010
    Posts
    72
    Post Thanks / Like
    If you were using the spray previously, and in cool, damp weather, it is possible that evaporation of the volatile carrier in the spray caused localized lowering of the temperature, causing moisture in the air to condense and cause cloudiness.
  3. #1153
    Join Date
    Mar 2013
    Location
    Buffalo NY USA
    Posts
    61
    Post Thanks / Like
    OK, drum roll please...
    I am very happy with the results. Absolutely no milky areas and near perfect uniform coating. GP49, you may be right. I may never know exactly why I was getting that milky look but at least now I can move on in my headlight project.
  4. #1154
    SELF BANNED
    Join Date
    Apr 2013
    Posts
    27
    Post Thanks / Like
    does it take off swirl marks off too.. my rear and head lights got small swirls on it.
  5. #1155
    Join Date
    Mar 2013
    Location
    Buffalo NY USA
    Posts
    61
    Post Thanks / Like
    It will virtually eliminate them
  6. #1156
    Newbie Member
    Join Date
    Jan 2012
    Posts
    3
    Post Thanks / Like
    So i skimmed through a lot of this thread but I'm stumped. Where can I find solvent based Helmsman Spar Urethane in California, specifically Orange County region? Or does anyone know a reliable site that will sell it by the quart?
    Thanks!
  7. #1157
    Super Member
    Join Date
    Aug 2010
    Location
    New Jersey
    Posts
    15,167
    Post Thanks / Like
    You probably can't buy that in CA due to VOC restrictions.
  8. #1158
    Newbie Member
    Join Date
    Jan 2012
    Posts
    3
    Post Thanks / Like
    Which site can I buy it from? I don't wanna order one and has it being water bases aha
  9. #1159
    Super Member
    Join Date
    Aug 2010
    Location
    Fairmont, MN
    Posts
    3,189
    Post Thanks / Like
    I do believe that "Ace Hardware" sells it. At least my local one does. I just noticed 'that' yesterday.
    But, if it is a no-no in California, they probably cannot legally sell it, or offer it for sale there.
    Maybe Amazon?
    Bill
  10. #1160
    Super Member
    Join Date
    May 2011
    Location
    Daytona Beach, FL
    Posts
    219
    Post Thanks / Like
    Quote Originally Posted by kewldetail View Post
    Thanks!
    Thats so weird!! Here in Florida you can buy the Spar at Lowe's, Home Depot, Ace, Walmart......almost anywhere!!
Page 116 of 142 FirstFirst ... 1666106107108109110111112113114115116117118119120121122123124125126 ... LastLast
Similar Threads
  1. Replies: 9
    Last Post: 08-11-2016, 12:55 PM
  2. DP Headlight Restoration Kit vs Mothers NuLens Headlight Renewal
    By RobertJ34 in forum Auto Detailing 101
    Last Post: 05-30-2014, 09:02 AM
  3. Headlight Restoration-new UV sealant idea** Summary**
    By ShineTimeDetail in forum Show N' Shine
    Last Post: 06-08-2012, 09:47 AM
  4. Headlight restore application method idea
    By websdown in forum Auto Detailing 101
    Last Post: 02-03-2012, 02:19 PM
  5. Headlight Restoration
    By truckbutt in forum Auto Detailing 101
    Last Post: 08-21-2011, 08:57 PM
Members who have read this thread: 3
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
