Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 60
    Super Member Hazcat's Avatar
    Jan 2013
    Wichita, KS
    680
    Re: More headlight restorations
    That is quality work. Customers in your area are lucky to have someone like to go to.
    Super Member Chris@AutoCleanse's Avatar
    Nov 2012
    St. Cloud, Florida
    1,551
    Quote Originally Posted by g35_coupe View Post
    I've been using Opti-Lens exclusively but considering matching something up against it in a durability test. Failure of the Opti-Lens will really depend on how it's washed and exposed to sun. Unfortunately, the cars I've coated have not returned. I applied it to my car but it ended up totaled in an accident years ago. You should get a couple of years out of it though.
    Thank you! Customers get pretty stoked when I'm able to salvage them.
    Most of the time 800 grit is enough to start with by hand then work up to 3000. Then DA with WG TSR and put on the OL. The Nissan Titan and Volvo lenses needed some really tough love and can be a total nightmare if it's your 1st set or don't have the right materials.
    Thanks. Surely those are aftermarket so I would definitely watch those for oxidation since the UV coating may not be a durable as the factory stuff.
    I appreciate the compliment!
    Thank you, sir!
    I use Dlux but did not know if opti-lens was better or not. I read mix reviews but I guess that goes for anything.
  3. #13
    Junior Member TylerHoffarth's Avatar
    Feb 2013
    Saskatchewan, Canada
    74
    Fantastic work, OP!
    Those lenses were BAD before you got there - and you made them TONS better.
    Owner of Unleashed Auto Care
    www.unleashedautocare.com
    Proudly Serving Automotive Enthusiasts Across Saskatchewan
  4. #14
    Oct 2012
    202
    Wow, you do fabulous work.
    You mentioned starting with 800 and finishing with 3000. What other grits do you use in between? Also about how many sets can you coat with one syringe of OL?
    Thanks.
  5. #15
    Super Member g35_coupe's Avatar
    Jul 2010
    413
    Quote Originally Posted by umana2482 View Post
    Thanks.
    You can go 1200, 2000 then 3000. You can safely double grades.
    For Opti-Lens applications, a 10mL syringe can yield about 8-10 sets if doing 1 coat.
    Mobile headlight restoration in the Oklahoma City area www.okcheadlights.com www.facebook.com/OKC.Headlights
  6. #16
    Jul 2010
    413
    A few more recent jobs....
  7. #17
    Junior Member Matt@flyingchipmunk's Avatar
    Sep 2015
    Central MA
    85
    fantastic work!
  8. #18
    Jul 2010
    413
    A Range Rover I took care of after Sam's Club did a poor rattle-can job "clear coating" them...
  9. #19
    Dec 2015
    261
    You should post a video with your technique!
    Have some questions:
    • What's your mobile setup?
    • For headlights with deep scratches, do you sand them until they are gone?
    • How do you deal with headlights that have cracks on them?
  10. #20
    Nov 2015
    Los Angeles, California
    13,765
    So you do all the sanding by hand? What kind of pad do you like for polishing out the sanding marks?
    Your results are top notch.👏🏼
  1. Headlight restorations & feedback, please
    By AllanS in forum Show N' Shine
    Last Post: 11-15-2016, 09:22 PM
  2. a few headlight restorations
    By g35_coupe in forum Show N' Shine
    Last Post: 12-30-2014, 01:49 PM
  3. Two headlight restorations.
    By mhphoto in forum Show N' Shine
    Last Post: 06-26-2012, 05:30 PM
  4. What do you guys use for Headlight Restorations?
    By bigaizsosexy in forum Auto Detailing 101
    Last Post: 08-26-2011, 03:55 PM
  5. New Guy Headlight Restorations
    By Helljumper09 in forum Show N' Shine
    Last Post: 08-05-2010, 03:56 PM
