Results 1 to 7 of 7
    Super Member 02nissanISR's Avatar
    Mar 2009
    260
    maxima headlights restored finally
    Finally did the lights on the Maxima no pitting or scratches just getting foggy and making my ride look bad.
    cleaned with stoners
    2500 grit wet sand
    Megs solo cut and polish w/solo yellow wool pad
    Megs 205 w/orange 3 in. pad
    ipa wipe
    helmsman spar urethane uv sealer 50/50/ mix with mineral spirits.
    buffing was done using the flex 603 15-1800 rpms
    after wet sanding
    After
    Regular Member SpotlessDetail's Avatar
    Apr 2009
    charlotte NC
    104
    Re: maxima headlights restored finally
    Looks great! good as new. Was much needed.
    Nothing is clean until its Spotless
    Super Member dublifecrisis's Avatar
    Mar 2008
    Jacksonville, Fl
    1,158
    great result! I've seen older cars lose years of age with a headlight resto.
    Jan 2007
    1,153
    Wow, they came out great. I think I may be trying this method on one of my cars that can really use it. Thanks for sharing with us.
    Super Member HotRod's Avatar
    May 2008
    247
    Looks good! I am not sure why some members are scared to try this method. It works and lasts longer than anything I have tried before(urethane mixture). And it can be wet sanded off easily just like the original coating, I tried it, if you don't like it, it can be reversed even after its been cured. This method is cheaper than a new set of lights, so in my opinion its worth a try.
    Mar 2009
    260
    Quote Originally Posted by HotRod View Post
    Can I get an AMEN from the congregation the only other stuff I might try is the Klasse just because I have some. But you are dead on right HotRod sometimes people get hung up on the fact that "it wasn't designed for that" but I heard many experiences on here of people using things they were not necessarily "designed" for with good results.(woolite comes to mind) Im sorry but you can't argue with result man.
    May 2008
    247
    I have tried Klasse, it works well on paint, but does not last as long on plastic lenses, from my experiences. I don't think the urethane will last forever, but nothing else makes them look good and stay that way longer. IMO
  1. Headlights restored
    By Beavis in forum Show N' Shine
    Last Post: 06-07-2015, 09:39 PM
  2. Can these headlights be restored?
    By rpm4242 in forum Hot topics & Frequently Asked Questions
    Last Post: 03-22-2015, 08:29 PM
  3. Restored Headlights?
    By DogRescuer in forum Auto Detailing 101
    Last Post: 05-06-2014, 04:58 PM
  4. Some more restored headlights for you.
    By mhphoto in forum Show N' Shine
    Last Post: 06-30-2012, 04:04 PM
  5. Headlights restored
    By slickooz in forum Show N' Shine
    Last Post: 05-09-2011, 08:59 PM
