03-14-2012, 04:51 AM
#861
Re: Headlight Restoration-new UV sealant idea
Can anyone tell me if there is a difference between the 3000 wet/dry paper you can get from onlineindustrial supply and the 3000 trizact? Is it that much of a difference? The price is so much higher and the 3000 I have been using seems to work fine.
Also, I have seen some sites recently like Home | Headlight Restoration | Doctor Headlight claiming they have some "emulsion" process that goes through the light to take out even issues inside the light without removing it. Also, Headlight Restoration Professional Preferred Method, Rated BEST! claims to have a "3rd generation chemical" which dissolves all old coating and doesn't need any sanding.
Has anyone had any contact or info about these or what they are using for their products?
Thanks in advance,
Norman
03-14-2012, 09:48 AM
#862
Here is a written description of the process, reported by a Doctor Headlight customer on Rennlist (a forum of Porsche owners):
He first asked forum members about it:
Has anybody here ever used Doctor Headlight for headlight restoration?...They send a tech out who will perform the job at your house. It takes about an hour. I was quoted $90 for BOTH headlights.
According to the tech, they use a 5 stage sanding process to remove imperfections, and they follow it with an epoxy coating to protect the newly polished lens. It's guaranteed for life. I think I may try this... my headlights are getting a little hazy and showing some yellowing...
Then he tried it and reported back:
The headlight refinishing process is complete. It was 30 degrees F and snowing today, so I had the work done in my garage. The tech started by wet sanding the headlights with an emulsifier. He hand sanded progressively, going from 320 to 600 to 1,000 to 1,500 to 2,500 grit. He then treated the lenses with a conditioner, and finally 3 coats of epoxy applied from a small air gun. Because of the cold weather, he then used a heat gun (a.k.a. fancy hair drier) to help dry the epoxy.
I'm very pleased with the results. The lenses look much clearer, and most of the imperfections have been removed. Are they as good as brand new headlights? No. However, they are a dramatic improvement and it was money well spent. Here are a few before and after photos...
...which you can't see unless you are a forum member and signed in.
The entire thread can be read by nonmembers at:
Doctor Headlight - Rennlist Discussion Forums
So, it sounds like the same familiar abrasive process to remove the oxidation and deteriorated factory coating (the "emulsifier" is still not described), with a clear epoxy sprayed onto the headlight to protect the restored lens from UV.
Other customer reports say the cost is closer to $200 than to $90 but since the vendors are all independent businesses, they can charge what they want.
03-21-2012, 11:23 PM
#863
I have been using this 50/50 method and other than a couple times that I have somehow missed a small spot and have to clean it up and start over, it works great. I have been using rubbing alcohol to clean up and it seems to work fine, but I have seen people suggesting using the mineral spirits for that as well.
Has anyone used both and can shed some light on why I should or shouldn't use either one?
I would love to start doing the 2 part clear such as a 2k spray but when you are mobile and have limited tools, it's just not possible to pull headlights to do that in a clean and controlled environment. I have been thinking of adding it as a optional "premium" service but I am not sure I want to start disassembling car parts. So for now.... 50/50 is working and I don't see a need to change it.
03-23-2012, 02:46 PM
#864
I use the mineral spirits for the 50/50 mix with the spar....and....to wipe the lens clean from sanding, prior to applying the spar mixture...and it works great. No reason to buy rubbing alcohol too.
The problems that I hear from others on here about using an air brush to spray is.....1. The extra time it takes to mask all surrounding surfaces to avoid overspray and....2. You have to be careful that the overspray doesn't get on any other cars close by...as many people perform these job for car lots.....and 3. Is the additional money used for the materials used to mask everything off.
The wipe-on 50/50 (I use 60/40) method is easy and neat with little costs or clean-up.
03-23-2012, 02:58 PM
#865
For this part I also use mineral spirits.
My question was pertaining to if you mess up applying the 50/50 or 60/40. What do you use to clean that?
I gather from what you said, you don't have alcohol but how how much work is it to use the mineral spirits? I can completely clean a lens of the still wet 50/50 in about 30seconds with the alcohol.
Thanks for the input.
Conduct yourself with integrity, in business, and in life.
Rich
03-24-2012, 05:27 AM
#866
I use the mineral spirits to clean off if I mess up putting on the spar also. It comes right off when its still wet and as long as it hasn't dried for a half hour or so, your ok.
03-24-2012, 06:12 PM
#867
03-24-2012, 08:21 PM
#868
The mineral spirits that I use are absolutely clear and has the same consistency as water.
And when mixed and ready to use it is still clear. And I wait for any bubbles to go away before I wipe it on with Scott Shop Towels.
03-24-2012, 09:38 PM
#869
Shouldn't Spar & MS mix be like an amber color? MS is clear/transparent, like water, and feels oily when you touch it. Spar is about amber or yellow. When I mix the 2, i get an amber color.
I've been using this method for the past 3 months and I've had no troubles; results are impressive!
Is everybody getting an ambered color mix? or is it a clear one?
03-24-2012, 11:02 PM
#870
Yes. Amber colored.
By clear I was referring to the fact that what he was ending up with was opaque with no transparency.
My mineral spirits are clear, the Helmsman is amber(ish).
By geoguy in forum Show N' Shine
By ShineTimeDetail in forum Show N' Shine
Last Post: 06-08-2012, 09:47 AM
By websdown in forum Auto Detailing 101
Last Post: 02-03-2012, 02:19 PM
By truckbutt in forum Auto Detailing 101
Last Post: 08-21-2011, 08:57 PM
26 | 27 | 28 | 29 | 30 | 31 |
