Re: Wheel Wednesday!
Originally Posted by Ace22
As a self-proclaimed wheel Czar, I proclaimed that to be in the top 5 wheels ever created in the automotive industry
2022 Elantra N Cyber Gray
This week, the superbly simple but effective 18-inch items that featured on my Tickford T3 TS50. Back in 2002, 18-inch wheels were considered big, and for a Ford at the time, they were positively HUGE!
These wheels were fitted to the one-year-only T3 TS50, with less than 220 manufactured between November 2001 and September 2002. All T3 models (TE50, TS50, TL50) were fitted with a hand built stroked Windsor V8, taking capacity from 5.0 to 5.6 liters. Both a 5-speed Tremec manual and BTR 4-speed auto were offered, mine was an auto. All engines had the signature of the engine builder on the right-hand rocker cover, and all cars had a build number, mine was number 154 -
Build 154 T3 TS50 – T-Series Club of Australia
I bought the car from the original owner in January 2012 with only 47,000 km / 29,000 miles on the clock. This was also my first V8, and what a lovely noise it made too. Very few Falcon's have as much presence on the road as this Tickford T3 TS50. The original tag line for the car was "Own The Road"...................
I sold the car in late 2014 in anticipation of my current Falcon XR8, it hitting the road to be transported to its new owner, who contacts me from time to time to let me know how its going. When it arrived at the new owner, the battery died during the journey and ended up needing a jump start to get it off the truck..................all while holding up traffic outside the guys shop on the main street. I felt terrible about that, but sh.t happens.
It was pretty sketchy getting the thing on the truck, the ultra-low bumpers posed a bit of a problem, and that was with the factory ride height.
I do miss the exuberance of this car, the bright "Blueprint" paint, the shouty body kit and spoiler, the glorious noises it made. And it used fuel at a hilarious rate. I'm sure I'll regret selling this car one day, but I wanted to have one of the last Falcon's, so it was goodby to the "Ticker".
Funny how wide car tastes can very from person to person. 🧍 respect you as you are a wheel guy and you have good taste in cars but those don’t due it for me personally. Not top 5 anyway.
I like your Kona N’s better myself.
Those do a nice job of showing off those gigantic Brembo’s tho…
Wheel Wednesday!
Originally Posted by Eldorado2k
Mustard and Mayonnaise!
Those are gonna look good!
That's a beautiful ride right there. I wish they sold those in the states. Did these have the 4.6L with 4V heads?
Edit: Oooo, I see in your post they had 5.0 and 5.8L. 5.0L were pushrods here in the states until the 94 Mustang. Were they still using pushrod V8's in AU for this one?
So, the OHV Windsor V8 continued in Falcon right up until September 2002, where it was then replaced the by the 5.4 Modular V8 in 3V SOHC and 4V DOHC configurations (more on that in a sec.)
Ford Australia actually stockpiled Windsor V8's to carry them through until the new BA Falcon arrived in September 2002. The Falcon was the last Ford to have a Windsor V8, and by that time, its was pretty much outclassed by Holden who had moved to the GEN-III small block in 5.7 liter capcity across all models.
The Windsor was offered in a number of power formats in its last years.
175 kW / 235 HP - this was the optional engine on Fairmont's and Fairlanes, Utes and even the base model sedan with the plastic hub caps!
185 kW / 248 HP- this was the early XR8 engine, but was also used on the LTD limousines.
200 kW / 268 HP - this powered early TE50's, and mid series XR8's.
220 kW / 295 HP - this powered the early and mid series TS50, mid series TE50 and mid to late series XR8. These were partially stripped and rebuilt using alloy heads or machined iron heads later on. They even port matched the head and intake manifold. These engines are the sweet spot, very mean sounding.
For the last T-Series models, the 5.0 Windsor was stripped down and rebuilt with a locally spec'd stroker kit, taking them out to 5.6 liters and 250 kW and 500 Nm (335 HP / 369 ft.lb). They had a lot of local hardware including the cams, intake manifold, exhaust, valve train, rods, crank..................they were pretty special engines. Because of the big cam, they would rock at idle like an old school muscle car, and sounded like one two.
Engine video from back in the day -
Some Windsor warble (skip to 1.45.............
This guy annoys me, but he is one of a few that makes videos on these cars (6min for the noise)...............
As mentioned, in 2002 Ford launched the heavily refreshed Falcon with a range of new engines, including the first appearance of the newer Modular V8's. Ours were a bit different to what was offered in the US. The base SOHC 5.4 V8 had the 3V alloy heads on the iron block, which was the from the F-series, but teamed with local intake and exhaust manifolds. That engine produced 220 kW / 295 HP. The 3V was optional in Fairmont, Fairlane, and the workhorse utes, standard on LTD. They were basically a tow engine, low revving and a deep sound to them.
For the performance models, Ford locally assembled their own version starting with the 5.4 iron block, teamed with the alloy DOHC 4V heads, a locally designed intake manifold with huge pod filter, exhaust manifolds, all hand built. These engines powered performance Falcon's from 2003 to 2010, offered in 260 kw (349 HP), 290kw (389 HP), 302 kw (405 HP) and 315 kw (422 HP) power levels. The problem with those engines was the soft low-end torque, mainly because the 4V heads had no variable valve timing like the 3V version did. And because of the ultra-long 105mm stroke, they were limited to 6000 rpm, and later 6500 rpm with the Ford GT crankshaft, meaning they had a 2000rpm power band. But..................they sounded amazing with a really cammy sound and feel.
So, in summery, the Holden's were generally faster, but sounded like a fart in a funnel. The Ford's sounded richer, more raunchy.
Post Thanks / Like - 2 Thanks, 4 Likes, 0 Dislikes
I watched the last video and have a bit of an issue with reviewers like him, just a minor one. In the beginning he says this example is all stock....except custom exhaust, intake and tune...that's NOT stock anymore Now don't get me wrong, most of do 2 or all 3 of those mods on our cars but come on, don't say "it's all stock...except".
Thanks for always sharing your knowledge Deyon, you guys got those and we got the Lincoln LS, not even close to the same thing but if you had a family and wanted a Ford product that was RWD and V8 and fun (sans the Lincoln or Crown Vic) that was your only choice for something "close" and I use that term VERY lightly️
DFB liked this post
This popped into my news feed a couple of days ago, you probably already know all about this one, they just needed a bit more courage.
https://www.drive.com.au/caradvice/a...oor-prototype/
By topperjohn68 in forum RV & Motorhome Detailing
Last Post: 03-29-2018, 09:50 AM
By Elliot@Autogeek in forum Sales & Promotions - For forum members and non-forum members
Last Post: 05-31-2017, 12:14 PM
By Dave_k in forum Show N' Shine
Last Post: 12-05-2015, 10:26 PM
By 57BORNTORUN in forum Off-Topic
Last Post: 10-27-2012, 10:04 PM
Members who have read this thread: 64
- MailMan17,
- brianshaeffer,
- chilly,
- scottlee,
- melF1fan,
- Karl_in_Chicago,
- bill walsh,
- Wknd Dtlr,
- Bobby B.,
- scshaysc,
- Setec Astronomy,
- IID,
- Jplouch,
- georgia boy,
- hansen97,
- delt1964,
- raysaint,
- D.BRITT,
- azdetail,
- SJP4379,
- xabo,
- Ace22,
- Azure,
- The Guz,
- wierdkid,
- Alansr,
- Desertnate,
- aim4squirrels,
- rmtaylor51,
- LSNAutoDetailing,
- 11Silverado,
- 03me,
- FocusSTguy,
- Garagehack,
- tradecraft1,
- oneheadlite,
- Matador,
- cyclops,
- TTQ B4U,
- Prange,
- SNP209,
- Willbeen,
- Tasmania,
- UncleDavy,
- Darth Enzo,
- bradp674,
- Mklauss,
- DFB,
- Icarus,
- Odrapnew,
- DUBL0WS6,
- msharpe785,
- dbeng,
- Thunderchicken,
- Bosko,
- Forty,
- DanaDetailingPros,
- Tbonem3,
- cb804,
- Optimus Grime,
- Dirty Harry,
- aannatshlzea6696,
- kappy,
- bapatickmjnra7168
26 | 27 | 28 | 29 | 30 | 31 |
