Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    May 2013
    TN
    857
    Re: Help! I made a bit of a mess with a Bigfoot
    I’ve been using the Rupes coarse blue wool often for polishing home theater subwoofers with a lacquer finish. It can really remove the defects and finishes pretty well though I do a 3 step with Rupes blue coarse wool and Buff Shine Uro-Tec blue coarse foam followed by Uro-Tec dark blue medium polishing pad finished off with a Buff Shine white polishing pad.
    I’m sure the Rupes yellow wool pad is a good medium polishing pad with nice finish down but would likely need some extra polishing with a softer foam pad to get “perfect”.
  2. Likes chilly liked this post
  3. #22
    Super Member chilly's Avatar
    May 2006
    Hawaii
    363
    Quote Originally Posted by dgage View Post
    Iíve been using the Rupes coarse blue wool often for polishing home theater subwoofers with a lacquer finish. It can really remove the defects and finishes pretty well though I do a 3 step with Rupes blue coarse wool and Buff Shine Uro-Tec blue coarse foam followed by Uro-Tec dark blue medium polishing pad finished off with a Buff Shine white polishing pad.
    Iím sure the Rupes yellow wool pad is a good medium polishing pad with nice finish down but would likely need some extra polishing with a softer foam pad to get ďperfectĒ.
    Iím sure you are 100% correct
    I wasnít implying the OPís first attempt would have worked out with a Rupes yellow wool pad
    I was simply seconding the advice not to count out wool as an option for paint correction with a DA
    I thought for years that wool was never an option, I was trapped in the wool with a rotary equals a nightmare thought pattern
  4. Likes dgage liked this post
  5. #23
    May 2013
    TN
    857
    Quote Originally Posted by chilly View Post
    I’m sure you are 100% correct
    I wasn’t implying the OP’s first attempt would have worked out with a Rupes yellow wool pad
    I wasn’t even thinking I was counteracting your advice. I agree that wool is a valuable tool in the arsenal. I am surprised how well the Rupes coarse blue wool removes defects and still finishes out pretty nicely. I haven’t used the yellow wool either but I’d think it would do the same on more moderate defects. But likely would still need a second pass with a softer foam pad but that is a guess on my part.
  6. Likes chilly liked this post
  7. #24
    May 2006
    Hawaii
    363
    I wasnít even thinking I was counteracting your advice. I agree that wool is a valuable tool in the arsenal. I am surprised how well the Rupes coarse blue wool removes defects and still finishes out pretty nicely. I havenít used the yellow wool either but Iíd think it would do the same on more moderate defects. But likely would still need a second pass with a softer foam pad but that is a guess on my part.
    No, you are correct
    I think anything you paired it with that had any correction vs polishing capabilities would need a follow up
  8. Likes dgage liked this post
  9. #25
    Super Member mc2hill's Avatar
    Feb 2009
    Orlando
    547
    Paint hardness is the variable. Wool might work for some and in some cases it may be too aggressive. Your test spot will always let you know.
    So donít give up on wool. Foam is good for finishing but not always cutting.
    I am with Michael on this. After talking with Jason Rose at Mobile Tech Expo in early 2020 I tried the Rupes yellow wool and DA Fine compound. I was amazed at how quickly it corrected swirls, and because it stayed cool I could work a larger area + do less passes (e.g. the whole door in 2-3 passes [4-6 the way Mike P. counts] vs. 1/2 the door and 4 passes [8 Mike P.]). For clarity, this was a 'production' type detail, on burgandy Infiniti paint.
  10. Likes The Guz liked this post
  1. Ziebart made a mess of a brand new truck
    By Hoytman in forum Auto Detailing 101
    Last Post: 09-13-2014, 11:17 PM
  2. Dealership made a huge mess >:(
    By SiliconX in forum Auto Detailing 101
    Last Post: 06-19-2014, 02:42 PM
  3. OYE! Just made a mess of my friends spoiler
    By dcjredline in forum Auto Detailing 101
    Last Post: 06-10-2014, 03:06 PM
  4. Made a mess already :*o
    By gsf in forum Auto Detailing 101
    Last Post: 09-09-2009, 03:59 PM
  5. Made a little mess
    By Fanged03 in forum Auto Detailing 101
    Last Post: 11-06-2007, 08:05 PM
Members who have read this thread: 100
» January 2022
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31 12345
