Re: First time using Rupes 15 mark II and I must be doing something wrong...
Originally Posted by custmsprty
It has for me with all three of my Rupes polishers and my G21.
I agree. No pressure is really required to remove majority of the defects when using long throw polishers in my experience. Maybe some deep ones.
I don't mean like leaning into the panel kind of pressure, more like a firm grip/slightly more than that at all times.. But just the weight of the machine type of "no pressure"? That's pretty rare.
Seen it too many times, guys use a long throw like a 3401. With a 3401 you really need to press down or use pressure to get any correction out of it. When they jump from a 3401 style of aggressive polishing they forget the newer tech long throws are more finesse type correction devices.
Me too. Heck, I barely use any extra pressure on the porter cable, and that thing will still do the job in a timely manner.
If you noticed, I stated I have them all. And have used them all..
On page 2 of my RUPES how-to book in the Introduction and also on page 62 under the section,
11 Tips for using all RUPES BigFoot orbital polishers
You'll find this,
(screenshot of the actual book page)
Technically the FLEX 3401 is a short throw or short orbit stroke orbital polisher.
The orbit stroke of the FLEX 3401 is 8mm which is the same for these polishers,
Porter Cable
Griot's Garage 6" DA
Meguiar's MT300
The FLEX XFE& is a 15mm orbit stroke orbital polisher as is the Cyclo polisher and these would be considedred long stroke.
I don't know where the cut-off line is for short stoke and long stroke? I also don't know who would be the deciding authority?
RUPES Duetto and Mini are 12mm orbit stroke lenght oribital polishers and that's only 4mm more than the 8mm tools like PC, GG and Megs.
As the guy that originally started the firm pressure technique for short orbit stroke polishers I'd say you're correct. From over 12 years ago... time stamp is September 27th, 2004
Using the G-100 to remove swirls with the Professional Line
When using the G100 Dual Action Polisher to remove defects, (This is different then merely applying a polish or a wax because you're trying to remove paint), you need to use a slow arm speed, overlap you passes by 50% and apply between 15 pounds and 20 pounds of pressure onto the head of the polisher.
To get an idea of how hard this is to push down, simply place your polisher onto an everyday bathroom scale and then press down on the head of the polisher and take note of how hard you're pushing. If you like, you can even tape some heavy plastic around the scale as you can see that I did in the below picture and actually turn the polisher on and practice pushing down as you move the polisher around. Also listen to the sound of the motor to get an idea of how it sounds at the pressure you are applying. Make sure you have someone to hold the scale in place when you do this.
15 pounds of pressure on the head of the polisher
20 pounds of pressure on the head of the polisher
I'd agree 100% with the above and in my RUPES how-to book I include a lot of finesse type tips for using RUPES polishers.
If it's stalling on flat panels I would suggest having someone watch you and make sure you're keeping the tool level. I'll run my MKII 21 at speed 3 all day long without stalling issues and do so without using Rupes pads and polishes. It's a bit of a learning curve but with the added power of the MKII you really shouldn't be having issues, especially if you're running at a higher speed like 4-5. If you can take a video of yourself working a section we can probably help narrow down what adjustments need to be made.
Rodney,
Sorry I'm late to the party, but I replied to your PM just now and looks like you've gotten a lot of the same advice I would've provided here.
Mike makes the point best - the bigfoot system will require you to rethink your approach to polishing if you're coming from a traditional orbit tool or gear driven tool, but I'm confident that you (like many before you) will figure it out after a little more time logged with the tool.
Porter Cable
Meguiar's MT300
Perhaps we should establish the world council for orbital tool standards Mike?
Also, consider this - when you say the LHR12E Duetto and LHR75E are "ONLY" 4mm larger orbits... thats still 150% of the traditional orbit tools. Thats a big jump... not nearly the 250% jump of the 21, but still significant. IMHO 'large stroke' begins at 12mm and goes up from there.
Last Post: 09-14-2016, 03:13 PM
By Elger in forum Wool & Foam Buffing Pads
Last Post: 06-21-2016, 09:32 AM
By The Guz in forum Show N' Shine
Last Post: 05-21-2016, 07:46 AM
By alegend in forum RUPES BigFoot Oribital Polishers
Last Post: 05-15-2016, 08:21 AM
By SonOfOC in forum RUPES BigFoot Oribital Polishers
Last Post: 12-25-2015, 04:20 PM
