Re: DA Flex or DA PC
See I have a rotary, but most of the jobs that I get don't need it. And when using the rotary I always have to follow up with a PC step to remove the imperfection the rotary has created. And that is extra time. The customer base that I have right now, don't need/want a full correction, they just want it "clean", so a single stage polishing step is all that I really need. I do try to up-sell, but it's tough when your customer don't understand or appreciate what a full correction is. Also it doesn't make much sense for a daily driver. Since the PC and Flex can achieve the same results, I guess I would go with the machine that saves time, since my business is volume based. Does the Flex really offer much in time savings? It's about twice as much as the GG 6". Just want to know if it's worth the investment.
It's definitely going to do any correction or polishing work faster than a PC style DA Polisher.
If you're doing one-steps using a cleaner/wax it will also be faster. Free floating spindle bearing assembly just can't compete with direct drive, forced rotation Flex 3401
If you get one, I would recommend springing for the Adapter Plate System so you can have the ability to use 4" pads for tight areas or thin panels.
Also, the Purple Foamed Wool Pads work really well for correction work on the Flex 3401 and for foam pads, stick with thick pads, not thin pads. The thinness or thickness of a pad is not a factor with the Flex 3401
One more question Mike,
have you ever used Meguiar's micro fiber correction system with the Flex?
If the Flex works faster, I assume it would help the micro fiber correction system work faster also. Is there anything to watch out for with this combination?
My 2 cents...I own the Flex 3401 and love it. Never used the PC though. Look at it this way, one the initial corrections are done it's all in the up keep after that. According to the Pros, the Flex corrects faster than the PC. If you wash properly after the initial corrections, no matter which machine you choose, you will only have to spend minimal time with the buffer in hand.
Hope I said that right!
The general consensus seems to be that the Meg's DA MF system does not work well with the forced rotation action of the Flex.
The compounding step is "grabby", that is the pad grabs the surface and feels like it's throwing the polisher around instead of the pad oscillating it over the paint.
If you want to use ANY microfiber DA system, then at this time get a PC style DA Polisher.
If you want to use foam pads or the PFW then you're good to go with the Flex 3401
Read what I and others wrote about the MF systems here,
http://www.autogeekonline.net/forum/...o-you-too.html
Last Post: 07-30-2018, 01:38 PM
By UglyBetty in forum Auto Detailing 101
Last Post: 10-17-2013, 05:20 AM
By MichaelD in forum Boat & Marine Craft Detailing
Last Post: 10-16-2012, 01:28 AM
Last Post: 01-25-2012, 02:19 AM
By 02nissanISR in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 07-11-2009, 08:56 PM
