Originally Posted by
Detailing by M
good information. Maybe this will stop people from using an ounce of 105 and complain about it dusting.
I've never had a problem using 105 because I only use what I need.
Also turn your phone sideways when making videos!
I had a makeshift tripod so I was limited. Got a real one now just for the phone.
Sent from my iPad using Tapatalk - now Free
Re: Richy's M105 video (no dusting technique)
You are making me want to get a rotary! Man, that took no time flat!
M105 seems to work better on rotaries, all the issues I have experienced and read about were on DA type machines. I think for some reason M105 doesn't like DAs as much.
Thanks for sharing your technique with us Richy.
Detailing by M
That is the way I learned. Prime the pad by covering the entire surface and then add 3 time sized drops. I think now after watching this that for 105 it's probably not the best way to do it. Using water to prime the pad then very little product seems to work wonders. But as someone else has said, you are working Inside, something I can pretty much never do.
I will try this technique next time I use M105 though, very impressed with what I saw.
Calendyr
...you are working Inside.....
I work outside, in the heat, in the cold. It doesn't matter. People use way to much product.
Sent while I was Detailing or something related to detailing or...
richy
I'm not trying to cut MP's grass here, but with all the bad press and discussion about how badly M105 dusts (it doesn't for me), that I thought I would shoot a short video to show my technique and what I do to prepare the pads so you get the desired results. M105 continues to blow me away with its capabilities! Check it out:
(If you guys want, I will shoot another on a black car showing M205 and possibly both products)
Bump from the past
You still here Richy? I can't see the video. How did you wet your pad?
xabo
Thanks!.. I'm not sure though. I thought they were talking about his misting his pad with water and I didn't see him do it in this video?
jem7sk
At the the 6:55 mark you can hear him state that he wets the pad first and spins it dry.
