Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 58
    Super Member Garry Dean's Avatar
    Jun 2009
    Tampa, FL
    1,796
    Re: Richy's M105 video (no dusting technique)
    Thanks for shooting the video. I find that the majority of my dusting comes from over applying the product. When I cut down on the amount I use the dust is not an issue.
    Lubricating the pad prior to your pass will cut down on the dusting as well, but will also reduce the amount of cut m105 offers.
    Garry Dean - Tampa, FL - 813-846-4406
    Auto, Boat, RV, Motorcycle, Aircraft Detailing
    Premium Custom Detailing
    Nice video Richy.
    You mentioned cleaning your pad often... good advice. Use a nylon brush, or a pad washer or use the clean-your-pad-on-the-fly technique just don't break a finger, etc.
    Or have plenty of pads on hand and as soon as you find buffing becoming more difficult, like the product becomes gummy and hard to wipe off the paint, switch to a clean pad and you'll notice you're back to easy buffing again.
    New pads properly primed always buff best, as you continue around the entire car with the same pad most people will notice buffing becomes more difficult and that's because of the spent product that builds up on and in the pad. So take Richy's advice and clean your pad often.
    It also looks like you were feeling the paint on the hood to see if it was warm or hot?
  3. #13
    Super Member CEE DOG's Avatar
    Jul 2009
    Florida
    7,358
    Excellent video Richy! I really appreciate it. I always pick up something useful from you.
    Quote Originally Posted by Garry Dean View Post
    Garry, are you sure about that? I thought it enhanced the cut. I forget who it was I was talking about this at DF with but it was one of the vendors. I believe it went something like this: I told them that I sometimes use a spritz of water when dealing with dusting but that I was concerned I was reducing the cut. I was told that in fact the opposite is true. By thinning out the product I was allowing the abrasives to have more contact with the paint and therefore enhancing the speed at which it cut.
    :dancebanana:
    Sky's the Limit Car Care
  4. #14
    Super Member richy's Avatar
    Mar 2007
    Windsor, Ontario
    5,158
    Quote Originally Posted by kronos View Post
    I understand what you're saying, because when I use M105, I normally get either mild dusting, to zero dusting. IME, I've noticed that it's technique dependent and my technique usually has to adapt to the paint I'm working on. When my technique is bad, M105 tends to punish my feeble attempt and I'll notice traits from mild dusting to gumming. But as I adapt to the paint and improve my technique, the dusting and gumming goes away. I'll also echo your sentiments, M105 is bad***!!!
    Glad to hear it's working well for you too. You're right, if you get lazy and wait too long to clean the pads, the job suffers. It is a pleasure to work with 105 with a clean, damp pad.
    Quote Originally Posted by 07 z-oh-6 View Post
    Nice job, Richy.
    What speed were you using on the rotary?
    Thanks Mark. It was at 1000 rpm....maybe you can't understand my Chuckie Canucky accent!! LOL
    Quote Originally Posted by Shiny Lil Detlr View Post
    Man, talk about a Canuck accent
    Awesome video Richy, that's a great technique and a great demonstration.
    Rippin on my Chuckie Canucky accent, EH?!?! Don't even get me started on those Michigan accents now!!
    Quote Originally Posted by Jaretr1 View Post
    I have only used 105 once so far and on a white car so I couldn't really see the dusting if there was any. I was spraying my pad with XMT pad conditioner in between passes. Would this be equivalent to wetting the pad first?
    Probably was. Save yourself the $$ and just wash them out with water and spin them dry.
    Quote Originally Posted by A.P.A.D. View Post
    i need to get a rotary! u did 2 section passes where with my PC7424 i have to do like 4-6. what a time saver!
    Dude...YES YOU DO!! I love my Dynabrade. Tons and tons of torque. If you've only ever used a DA, the Dyna will blow your mind.. Much more powerful than the Flex.
    also i think my problem with dusting is over applying the M105. i do an X on the pad instead of 3 little dots.
    thanks for taking the time to do this video Richy!
    You're very welcome.
    Quote Originally Posted by cutter View Post
    Thanks Richy for the video and the great damp pad tip...I will surely try this.
    Please let me know how it works for you. I'd like to know.
    Mark, I think he said the speed setting was at 1000.
    Thanks for jumping in with that!
    Quote Originally Posted by JSMet View Post
    Megs M105 is the real thing. When used with M205, it polishes better than anything else I have tried. I used both with a Flex 3401, I can only imagine how it would have turned out if a rotary buffer was used. Richy, your video was superb, I didn't see any issues with dusting at all. Thanks for the demonstration.
    You're welcome. If you go super slow with 205 and the right pad (damp too), there is really no need to jewel the paint. It finishes brilliantly.
    Quote Originally Posted by DLB View Post
    Great tips on the 105 Richy. As you pointed out - not too much product. I know that was my problem the first couple of times with M105.
    Thank you for the video.
    DLB
    My pleasure Dalton!
    Quote Originally Posted by Tom Weed View Post
    Very nice and informative video Richy! I love 105! Last couple of details using a DA with the MF system, I'e been adding a few drops on the pads on along with the D300 correction compound for a little extra cut.
    Glad to hear it Tom. I buy it by the gallon now I love it so much!
    I hear you on that. I get myself in trouble when I don't do what's right.
    Actually, I disagree there. Do me a favour please and try it both ways right next to each other on the same panel. Do it dry first and then rinse out the pad, spin it dry and to a section right next to it. I think you'll find it performs better!
    Nice video Richy.
    Man, I knew I was preaching to the choir for you!! I'm glad you didn't take offense to me posting it here. I know you have all sorts of videos in the library here. I just thought it might help some folks.
    Quote Originally Posted by CEE DOG View Post
    Thanks Corey. As you know me, I do enjoy helping people.
    I have found my method cuts the best and also finishes down the best. I have tried many different ways too.
  5. #15
    Super Member BobbyG's Avatar
    Dec 2009
    Southeast, MA
    13,211
    Hey Richy,
    Great job on the video and a nice hands on showing what Meguiar's M105 can really do. I think where many get into a bit of trouble is using too much product.
    Meguiar's M105 is designed to be used as you demonstrated which clearly illustrated a successful correction and not dusting at all. A friend of mine was showing me what a horrible time he was having with Meguiar's M105 and I swear this stuff was slung and stuck everywhere...
    I find that I like both Menzerna Power Gloss and Meguiar's M105 when I use it with a Purple or Yellow Lake Country Kompressor pad. These pads are stiff enough to keep the product working against the finish and not simply absorb it.
    Awesome post Richy and thanks for the great video!!
  6. #16
    Nov 2009
    Pasadena, CA
    12,615
    What are you mumbling from 6:17-6:30?
    '03 Corvette Z06
  7. #17
    Super Member C. Charles Hahn's Avatar
    Aug 2007
    Lansing, MI
    3,103
    I'll take a crack at translating Yooper/Canuck to close-captioned English (at the risk of getting Richy started on those "Michigan accents"):
    "Truth be told this should really be hit with wool, but it's not gettin' that, it's gettin' a one-step, and this might just be it...."
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    http://www.cchautoappearance.com/
  8. #18
    Jun 2009
    Tampa, FL
    1,796
    I am not sure. I will try it both ways and see. I have always primed my pads with Whatever compound or polish I was using. I've never tried it that way.
  9. #19
    Jun 2009
    Tampa, FL
    1,796
    It seems to me that when you add water to a product you are diluting it thus making the product less effective... I am curious on this one. I will video my findings as well.
  10. #20
    Mar 2007
    Windsor, Ontario
    5,158
    Damn....Charlie....You're good!! Jeez, next thing you know I'll have you drinking Canadian beer!!!
    I hope you do and please share it with me. I have learned a ton from trying things on these forums that I might not have otherwise. Also, which those who know me can attest to, I tend to do things that are "outside the box".
    Quote Originally Posted by BobbyG View Post
    Hey Richy,
    Thanks Bobby. I bought a yellow LCC pad and hated it. Is the Kompressor one better? I found the yellow LCC just got the surface WAY too hot and didn't correct nearly as well as wool. I am a big fan of wool as you know. I can get my black tufbuff wool pads to finish down quite nicely with 105 too. Same thing....not too much product.
  1. Frustrated with dusting of Meg's M105. Alternative options?
    Last Post: 09-11-2018, 06:52 PM
  2. M105 and dusting
    By Misael7 in forum Auto Detailing 101
    Last Post: 09-15-2013, 08:42 PM
  3. The use of M105 in hot weather (dusting)
    By Jpatchley in forum Auto Detailing 101
    Last Post: 08-08-2013, 10:27 AM
  4. Replies: 16
    Last Post: 05-30-2013, 09:04 AM
  5. The Cure for M105's short working time and dusting issues
    By Lasthope05 in forum Auto Detailing 101
    Last Post: 11-19-2012, 08:54 AM
