Re: Homemade MasterBlaster....Will this work?
I just read in another post that the MasterBlaster draws 20 amps.
Does that mean that two 9 amp leaf blowers would have approx. the same combined power?
Originally Posted by allenk4
I wonder why it didn't work well with the smaller hose?
The MasterBlaster uses a 1 1/2" hose
The opening on the blower is 2.5" and using the 1.5" hose reduced the airflow substantially.
Looks promising.... let us know!
Does anyone have an answer for the MPH CFM question
This would be my take on the CFM & MPH (jump in anytime mechanical engineers). CFM [Q] should approximately double since you have 2 pumps in parallel. MPH [V] is a function of CFM by the continuity equation Q=V*A or V=Q/A, where A is the cross-sectional area of the conduit or the outlet orifice, so if you double the flow, you double the velocity for the same size orifice. Note that continuity doesn't fully hold for a compressible 'fluid' like air, but does give a reasonable result when pressures are low. You'll also have pipe losses and losses at the orifice that are highly dependant on your configuration; smaller conduits and orifices result in more losses. Based solely on my gut, I would say you might get 1.7 times the CFM of a single blower.
Time for the mechnical engineers to check my work.
Just be careful with the details... leaf blowers are horribly dirty things. We tried a couple, some years ago, and quickly gave up because of the amount of oily rubbish that ended on the surface.
These are electric blowers fresh out of the box, so that should not be an issue
How does this translate to increased MPH from running two 180 MPH blowers in parallel?
Would it be 1.7 x 180 MPH = 306 MPH ??
When the manufacturer says 180 MPH, I'm not sure where they are measuring that. If you are using the same orifice as the manufacturer, then yes. If you are using a bigger orifice, then velocity decreases, if using a smaller orifice, then velocity increases.
Pumps generate potential energy (head) and flow rate in the fluid. You'd want to know the CFM of the unit, (knowing the head would help, but unlikely to find that info) and details about the piping configuration and the orifice (outlet nozzle), from that, you could roughly determine velocity.
Using the applicable Bernoulli's principle/equations, would then help derive the desired velocity rate.
By Socalsteve in forum Ask your detailing questions!
Last Post: 09-09-2014, 06:27 AM
By allenk4 in forum Auto Detailing Tools and Accessories
Last Post: 09-05-2013, 02:02 PM
By lunchboxmunchy in forum Auto Detailing 101
Last Post: 09-02-2013, 12:55 PM
By atoy in forum Auto Detailing Tools and Accessories
Last Post: 11-30-2011, 07:07 PM
By Mobile detail in forum Products Guides
Last Post: 07-15-2011, 03:58 PM
