Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Nov 2009
    Pasadena, CA
    12,615
    Re: Wolfgang Paintwork Polish Enhancer - Review and How-to
    I had some PPE in the garage, so I decided to try it with Griot's ROP on my 07 z06. I washed, clayed, washed before the PPE.
    Here's what the white pad looked like after I finished. I washed, clayed, then washed before the PPE. For some reason, the pad looks more gray in the picture compared to in person.
    Newbie Member highroler's Avatar
    Mar 2011
    After washing and claying car, is it advisable to use WG Paint Work Polish Enhancer prior to applying:
    Wolfgang Total Swirl Remover 3.0
    Wolfgang Finishing Glaze 3.0
    Wolfgang Deep Gloss Paint Sealant 3.0
    Pinnacle Souverän Carnauba Paste Wax
    I previously applied the above products with a Meguiars Dual Action 6 Inch Polisher G110v2 and need to know if the above list of products needs to be removed prior to doing another multi-step detail...
    Mike in ATL
  3. #13
    Super Member jkk7479's Avatar
    Aug 2010
    Cliffwood Beach, NJ
    222
    Quote Originally Posted by highroler View Post
    Hello,
    Paintwork Polish Enhancer is to be used when the car has little to no swirls. I see you want to use the Total Swirl Remover and Finishing Glaze. The PPE is an unnecessary step if you are doing paint correction. However, after you have corrected the paint, whenever you want to do a detail again in a couple of months on your car and if the swirls aren't bad or non existant you can use the PPE and then top with your sealant or wax.
  4. #14
    Apr 2011
    106
    I have a brand new bottle of PPE 16oz if anyone is interested.
  5. Likes LeeperMfg liked this post
  6. #15
    Quote Originally Posted by jkk7479 View Post
    Hello,
    This is correct.
    If you're using the Wolfgang Total Swirl Remover it's going to more than do anything you could do with the PPE even if applied by hand. See this thread,
    Removing Scratches By Hand
    Choosing and using the right polish can be confusing because there are a lot of products on the market in general but the Paintwork Polish Enhancer is a light paint cleaner for primarily prepping paint in good to excellent shape for application of wax or sealant.
    So you would,
    • Wash
    • Clay (if needed)
    • PPE
    • Wax or Sealant
    As soon as you stepped up to the TSR and the FG, you no longer need the PPE as the multi-step approach will remove swirls and polish the paint to a high gloss perfectly preparing it for wax or sealant.
    A multi-step process with the above would look like this,
    Wash
    Clay (if needed)
    TSR
    FG
    Wax or Sealant
  7. Likes LeeperMfg liked this post
  8. #16
    Tagging onto an old review is okay, but usually it's better to start your very own dedicated thread for you detailing project.
    How to start a new thread & How to reply to an existing thread
    To your question...
    if you want to remove any previously applied wax or sealant before using an abrasive polish then "yes" you could use the Wolfgang Paintwork Polish Enhancer first and it will effectively remove any wax or sealant still on the paint. Not so much by mechanical action but because any coating you've left behind is really thin to start with plus wear-n-tear will remove wax and paint sealants over time.
    If it were me... I would wash and clay as needed and then start right in with the Wolfgang Total Swirl Remover.
    If it's staring enough to remove swirls and scratches out of a clear coat finish then it's strong enough to remove any micro, or sub-micron layer of wax off the paint.
    Does that answer your question?
    Just want to make sure I'm reading your post correctly.
  9. #17
    Mar 2011
    Mike
    Thanks for the advice!
    My basic newbie question was...
    When I go to do another multi-step detail this fall do I need to remove/strip everything previously applied? Sounds like the answer is No and the TSR will remove previous applications.
    Mike in ATL
  10. #18
    Correct.
  11. #19
    Mar 2013
    79
    Great article..... I live in Michigan and normally use the Wolfgang trio every 4 to 6 months. After reading throughout the forum, I understand the WPPE "is not" needed if using WTSR due to it removing the old wax/sealant. With that being said, I do have a couple questions;
    1) If no swirls are present when ready to re-apply sealant, wouldn't it be better to use WPPE instead of TSR? It seems that it would be less wearing on the clear coat.
    2) If the answer is yes to the above, would the following be the correct procedure?
    a) Wash/Dry
    b) Clay/Rinse (if needed)
    c) WPPE
    d) WFG (???)
    e) WDGPS
    As always, thanks for all your help and suggestions. Ray
  1. Help: Wolfgang Paintwork Polish Enhancer
    By sebastian12 in forum Auto Detailing 101
    Last Post: 08-31-2011, 10:02 PM
  2. Wolfgang Paintwork Polish Enhancer
    By mcpp66 in forum Ask your detailing questions!
    Last Post: 04-06-2010, 09:31 AM
  3. Wolfgang Paintwork Polish Enhancer
    By img in forum Auto Detailing 101
    Last Post: 08-05-2009, 09:31 AM
  4. Wolfgang Paintwork Polish Enhancer
    By scrape in forum Auto Detailing 101
    Last Post: 12-22-2007, 03:11 PM
  5. Wolfgang Paintwork Polish Enhancer?
    By MoBenzOwner in forum Auto Detailing 101
    Last Post: 11-01-2007, 02:14 AM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
