Results 1 to 8 of 8
Thread: Pc 7335 & 7336
    Feb 2015
    Ft. Lauderdale,Fl
    615
    Pc 7335 & 7336
    First post,hope I got it right.I just inherited one of each of these units.Ive always been a rotary buffer guy & used a old style orbital to apply the wax. From what Ive read,these units are a better way to go.Question is,would I be better off spending the money to put new backing pads on these 2 units or just upgrade to one of the Flex machines and get rid of the PC units?
    Aug 2010
    New Jersey
    15,173
    Re: Pc 7335 & 7336
    It's going to be a lot cheaper to put new backing plates on those machines than buy a Flex.
    What exactly are you trying to achieve with these, just replacing your "old style orbital" for applying wax? Or do you want to do correction with them instead of your rotary? The Flex is rotary-like, but it's a different animal than either your rotary or the PC's.
    Super Member aim4squirrels's Avatar
    Nov 2013
    DFW Texas
    1,078
    Re: Pc 7335 & 7336
    Refurbishing those machines, if it can be done for only the new backing plate and possibly the lighter counterweight for the 7336, would not be a bad idea at all. You likely could refine the finish of your rotary work on the last polishing step. Use the absolute thinnest flat foam pads you can find, keep it at 5" pad size or smaller and you've got a good little machine on your hands.
    I have one, and a flex as well, I typically grab the 7336 for applying waxes and sealants as it's a very light machine to hold and move across the surfaces, but when it was the only thing I had, it still got the job done.
    Aug 2014
    1,445
    Re: Pc 7335 & 7336
    If money is no issue, get a Flex 3401 and use the PCs to apply wax, or give them some other dedictated use, i.e. small BP used for tight areas, etc.
    The Flex is very, very nice...
    Feb 2015
    Ft. Lauderdale,Fl
    615
    Re: Pc 7335 & 7336
    The PCs were given to me so even with new backing pads & getting several different foam pads,I'm Still ahead of the game.My old 10" orbital may not have much life left,it owes me nothing.I used it for applying wax or polish and usually remove by hand.I use my makita rotary on the boat with the wool pads and apply the polish with the orbital.The orbital bogs down easily so it isn't good for much more than applying the polish.This is where i'm think these PCs might come in to play.From what i'm reading,I can use the PCs to do the same thing as the old orbital but are more versatile by using the different pads and wont bog down so much.I'm think putting the PCs to use & if I like what they do,I may upgrade to the Flex down the road.
    Nov 2013
    DFW Texas
    1,078
    Re: Pc 7335 & 7336
    A 10" orbital doesn't do much polishing at all, if we're defining polishing as removing defects by abrasion of paint/gelcoat. Most on this forum don't use the term polish in the generic sense like using a wax to "polish" a car. If you aren't removing some form of material, you aren't polishing.
    Those machines are good product spreaders, they just don't have the umph to correct the defects.
    The PC actually can be used to refine paint with an abrasive polish.
    Sep 2006
    2,397
    Re: Pc 7335 & 7336
    For how low of a cost it would be to get the 7336 going, it would be a great place to start. It is a solid machine and can get you going on DA correction. They apply waxes and sealants just fine. They may not be king of the roost anymore but will erase rotary holograms, and do general correction work.
    Autogeek OG. Attended detail fest I/II. Still detailing!
    Super Member jfelbab's Avatar
    May 2011
    Cape Coral, FL
    335
    Re: Pc 7335 & 7336
    I'd take those units to your nearest P-C service center (most ACE Hardware stores) and have new brushes installed and have the gearhead cleaned and lubed. Have the power cord checked along with the speed switch and they should last for years. These models may be old but most were built in the US and are very durable with occasional maintenance. I still have a 7336 (1995 vintage) running and it works well with the microfiber pads. Finishing foam pads work pretty well for jeweling too. Same results as a FLEX but it takes a bit longer.
  1. Add G9 from PC 7335?
    By bcgreen in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
    Last Post: 10-24-2019, 07:10 AM
  2. PC 7335 and pad recommendations
    By bcgreen in forum Wool & Foam Buffing Pads
    Last Post: 05-28-2017, 05:04 PM
  3. PC 7335 compared to other DA polishers
    By dublbass606 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 02-22-2014, 04:20 PM
  4. WG TSR/FG & PC 7335 Technique
    By xxxc5 in forum Ask your detailing questions!
    Last Post: 12-04-2009, 05:24 PM
  5. G100/PC 7335 Pad Suggestions
    By xxxc5 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 11-09-2009, 05:32 PM
