Page 5 of 5 FirstFirst 12345
Results 41 to 47 of 47
  1. #41
    Nov 2013
    157
    Re: Custom Paint Job - 1980 Corvette - RUPES & Gyeon - Extreme Show Car Makeover at Autogeek
    Hi Mike (and/or others that were a part of team),
    What were the temperature conditions when you started coating (temp/humidity) ?
    How much time did you let gyeon MOHS sit before removal?
    What was removal like (compared to other coatings like cquartz etc) ? I heard it continues to show some high spots on panels you've already cleared so requires to keep checking prior panels as well...
    Was one layer applied or two ?
    Any other application usage details you can provide for MOHS would be great.
    Great outcomes !
  2. #42
    Quote Originally Posted by sealthedeal View Post
    Hi Mike (and/or others that were a part of team), What were the temperature conditions when you started coating (temp/humidity) ?
    Off hand I don't remember the temperature and we don't have hygrometer in the garage.What I do remember was we had the garage door open when we started as it was cool and even cold outside last week.I'd say it was in the 60's or 70's - don't even want to guess what the humidity was?
    About a minute. Jeff McEachran from Gyeon told me the wipe-off can start as soon as 20 to 30 seconds after application.
    I spoke with him the day before the Corvette project.
    What was removal like (compared to other coatings like cquartz etc) ? I heard it continues to show some high spots on panels you've already cleared so requires to keep checking prior panels as well... Was one layer applied or two ?
    Wipe-off was easy. If you look at the pictures I posted, Jeff Bell was inspecting the paint with the SCANGRIP light for high spots and none were discovered.This is a very user-friendly coating.
    Any other application usage details you can provide for MOHS would be great.Great outcomes !
    Not much else I can add at this time. If you can, go to Mobile Tech Expo this Thursay and attend the GYEON class Jeff McEachran and I are teaching from 2:00pm to 2:45pm in the Dade/FLorida Keys room at the Double Tree Inn in Orlando.
    Mobile Tech Expo 2017 - Classes this year
    5: The benefits of coatings for your customers and your business
    Instructor - Jeff McEachran & Mike Phillips
    Room: Dade/Florida Keys
    Time: 2:00-2:45am
    Jeff McEachran from Gyeon and Mike Phillips from Autogeek share with you the benefits coatings provide your customers plus how they can increase the profit for each job.
  3. #43
    Quote Originally Posted by Trip View Post
    Looks great. What does a "high spot" look like after the coating is put on?
    Would one describe it as butter on a half slice of bread and half the side doesn't have it?
    I have examples in this write-up
    How to remove a Ceramic Paint Coating High Spot by Mike Phillips
    And also in post #2 of this review
    Review: GYEON Q2 ONE Enthusiast Ceramic Coating by Mike Phillips
    And I just wrote this article,
    Installing a Ceramic Paint Coating? You MUST have a GREAT hand held light to avoid high spots!
  4. #44
    Oct 2011
    49
    Now lets see what's really going on....
    These my friend are holograms....
    Can someone explain to me how to tell that the marks in the last 2 pictures are Holograms?
    To my eyes all 3 pictures look like swirls, and I don't see the difference between the first picture and the later 2 pictures. (except maybe more lines coming out from where the light hits...?)
  5. #45
    Quote Originally Posted by vaced View Post
    Sure - be happy to....
    Look at the wispy LINES or PATTERNS you see in the below pictures from my article here,
    The word holograms means a specific scratch pattern inflicted into paint using a rotary buffer
    See the LINES
    Holograms are a pattern of SCRATCHES that mimic or copy the direction a ROTARY polisher was moved over the surface.
    Swirls are RANDOM.
    Micro-marring is caused by ORBITAL polishers, they are not random nor are they caused by a rotary.
    Somewhere on this forum I have another article with pictures that shows the different types of paint defects.
  6. Thanks Eldorado2k, vaced thanked for this post
    Likes Eldorado2k, dgage liked this post
  7. #46
    Nov 2015
    Los Angeles, California
    13,206
    Good to see you, Mike.Custom Paint Job - 1980 Corvette - RUPES & Gyeon - Extreme Show Car Makeover at Autogeek
  8. Likes dgage, vaced liked this post
  9. #47
    Oct 2011
    49
    Swirls are RANDOM.
    I have tried to draw on that picture in your post:
    I see lines, which i draw on in red. I'm guess this is the direction the rotary was moved
    I see other (circular?) scratches, & I draw on (some) of them in blue. These look the same as swirls TO ME, but I THINK these are also from buffer spinning.
    Are these circular scratches (where blue lines are) holograms, swirls, or micro-marring?
    Custom Paint Job - 1980 Corvette - RUPES & Gyeon - Extreme Show Car Makeover at Autogeek-clay_mitt_003-jpg
    Thanks for the assistance.
  1. Pictures: 1972 Corvette Stingray - Original Single Stage Paint - Autogeek Extreme Makeover!
    By Mike Phillips in forum PICTURES: Wednesday Night Detailing Classes
    Last Post: 03-19-2019, 08:24 AM
  2. 1972 Corvette Stingray - Original Single Stage Paint - Autogeek Extreme Makeover!
    By Mike Phillips in forum Wednesday Night Detailing Classes - Info & Dates
    Last Post: 07-07-2016, 03:33 PM
  3. Replies: 31
    Last Post: 03-26-2014, 06:58 AM
  4. 1990 Corvette - Extreme Makeover Pictures & Process
    Last Post: 03-03-2014, 03:10 PM
  5. Sign-up - 1972 Corvette - Extreme Makeover - October 27th
    Last Post: 10-28-2011, 02:23 PM
» September 2023
2728293031 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
