Detailing Vehicle / Personal Vehicle
Good Morning AG's,
As the title states, I'm looking to purchase a vehicle to both detail out of the back of, as well as to use as my personal vehicle. I'm aware that using a truck or van is a tried, tested, and true form of mobile detailing, but I need a vehicle that I can use each and every day, to detail out of, commute to and from my day job, and use for all other general purposes.
Ideas: Currently looking at used 07' or newer SUV's with 4x4 or AWD.
1. Toyota FJ Cruiser
2. Honda Element
3. Ford Edge
4. Even considered a hummer haha.
Anyway, if you have any suggestions that would be fantastic.
Thanks, Kieran
Re: Detailing Vehicle / Personal Vehicle
Those are al plretty similar style vehicles. Why not consider a Ford Explorer also similar and plentiful meaning less expensive.
Have you considered a trailer? Might be more functional to work out of.
youve got to add a 4 runner to that list. reliable, easy drivers, easy to find, easy to work on.
To give anything less than your best is to sacrifice the gift. " Steve Prefontaine.
I want to keep my detailing equipment enclosed and out of the elements and safe. Also, living in a condo, I don't have the extra space to park a trailer.
Honda Element can literally be hosed out and has a lot of plastic trim that can stand up to more abuse than paint. Probably would also save some coin at the pump.
If you're looking more at the personal use aspect I'd say the Honda Element. If you're looking more at a business use for the vehicle, I'd say the Ford Transits might work well. The used ones are more prevalent now.
I'd likely say its a 60/40 split between personal use and detailing.
Are you up north? Do you need awd/4wd? Down south I see a lot of hhr's being used for shops. And the ford kovach? (Googled commercial ford vehicle and it pops up don't know the USA name) hhr could be a pretty sweet little detailing mobile vehicle if well organized. And iv seen the ones with I rear glass too
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government" Thomas Jefferson,
What kind of equipment do you have that would be the main question so that you don't buy a vehicle to small for all your stuff. And are you taking your own water.
Winter in NJ can be a sloppy mess and we get a enough foul weather to make an AWD or 4x4 a smart purchase.
I've thought about running my own water tank and I'm unsure whether I will or won't use one. If I end up using my own water, it would be no bigger than 60 gal tank. I will have an electric pressure washer, vacuum of some sort, Honda generator, and then you common detailing items.
By Jeremy1976 in forum Show N' Shine
Last Post: 02-27-2017, 03:06 PM
By LSNAutoDetailing in forum Off-Topic
Last Post: 01-25-2017, 10:15 PM
By Zalmon in forum Auto Detailing 101
Last Post: 07-25-2016, 01:56 PM
By dano126 in forum Auto Detailing 101
Last Post: 08-23-2015, 08:32 AM
By scottgt in forum Show N' Shine
Last Post: 02-14-2008, 04:12 PM
