Re: SEMI transport truck pointers
Originally Posted by tuscarora dave
I've bitten off more than I could feasibly chew many times over until I figured out what to use and how to use it on totally neglected commercial vehicles. It's kind of like paying your dues to get good at it.
How well do you know this client? Tell him you need to do some testing with a few different products and processes before estimating the job, do some test spots and get back to him with an estimate. It really is a big job and if you struggle through the entire thing due to lack of experience, is it really fair to charge him for that lack of experience? You're best off being 100% honest with him up front that you need to find out exactly what you need to do to get the results he wants, and the only way to do that is to do some testing. Then do the math, figure out a ball park amount of time you think it will take you to finish the job, then add a little time to your estimated number to cover unexpected problems that take more time.
It's not easy to throw a number out on a job like this. If you think the bill should be $1500, throw out a number of around $2200 and let him negotiate you down a little if he needs to. Really it depends on what you need to make per day and what he needs to stay within budget wise. It's better to collect the required information in doing the testing, to put out a good accurate estimate and have him pass than it is to throw out a low ball number and get ripped on the job. If you do that you'll be pissed off for doing it and he'll expect to pay a low ball number moving forward.
What is a good days pay for you? What kind of overhead do you have to cover? What will you need to pay for in materials to get the job done? Add up your expected daily labor, add in for a helper if you'll have one with you, times that by the number of days you think it will take after doing your testing to see what you're actually dealing with, add in the estimated cost of pads and products + shipping. You're not in this to break even so make at least 30% on all your materials, add that in...what's your total?
If it cleans up fairly easy I could see having 25 to 30 hours in making it look real good if you're doing the trailer and the rig. If it's totally oxidized to hell and gel coat you could possibly triple that time.
One thing I know for sure is that you almost always take a whoopin until you get good at this stuff.
Works exceedingly well in cleaning up the paint on these commercial vehicles, and of course it'll do a good job on the metal too.
Hadn't, but I just googled it. looks like a racing VW Gulf. What about it?
That's the one. Admin might not be too happy about the link being posted here though.
i detailed that right after, by the inventor himself !!!
Yeah!! I've definitely payed my dues!! I can't tell you how many times I've grumbled under my breath about nothing working on these things , just to go out and buy another $50 quart of something that also wouldn't work.
Or...Sprayed on a strong cleaner starting at the top instead of at the bottom before a wash only, just to find that now I'm left with clean and dirty streaks that in the end had to be polished off because no amount of scrubbing would produce an even clean look...
Or....allowed that same strong cleaner to run down over clean and shiny uncoated aluminum just to have to repolish to remove the resulting etchings....
Thanks for backing me up on the paying your dues thing, you've clearly been there and done that!!
HEY ANYONE THATs done these kind of projects whether one time or numerous times know what you are saying, i dont think no one thats doing projects like this says i know what to do!! our first thought when we look at something this big is what did i get into!!!and those that just try n mess up like burning the paint n giving up after that just mean its not for you unfortunely but those that look for answer on how to or this that!! and make it happen like you said DAVE Thats paying your dues!!CAuse one thing about it once you take on a sucker like this n finish !BEST SATISFACTION IS KNOWING YOU CAN DETAIL ANYTHING BIG OR SMALL !! THATS WHEN YOU KNOW WHETHER HAVE A 3 figure businnes or doing it JUST ENOUGH < THAT YOUR WORK WILL ALWAYS BE A SATISFACTORY !!!!GURANTEED Or your paint burned!!!
true. sorry still new to the forum, my etiquette is not as refined as most. But trust me I by 90% of my detailing products from here so we are good. I just google it and thats what came up.
Originally Posted by Mantilgh
Dave, thank you for all the information that you are supplying here. Not to thread jack, hopefully my questions will add to this and help others that have questions.
Could you let me know if there is a way to tell if I have a single stage paint or a gelcoat?
I have a 97 Volvo straight truck painted Lunar Yellow and thought it was just single stage paint until I read some of your post, now I'm wondering if it is a gelcoat.
I have not attempted to work on it. We did have mid 90s Frieghtliner painted the same colour that I "cleaned" up using Meg's #9. Seemed to work well, and was planning on doing the same to the Volvo in the spring.
Any suggestions for removing staining from paint, either single stage or gelcoat?
The #9 seemed to work alright for stain removal on the other truck.
Truck is very stained but only really noticeable on the side section below the windshield (from nasty truck stop self serve window wash) and on the fuel tank.
Also, the bumper and fuel tanks seem to be lighter in colour than the rest of the truck and bumper is much more oxidized.
Give me a rough date on when you are planning on doing this project and I'll lend a helping hand. I will bring tools and supplies. Need at least two weeks notice or I can load a run through your area.
I believe the biggest issue is rust transferring from the steel hay rack. Evidenced by the staining of the fuel tank. Tank is painted??? Bummer
My last project was a cherry.
2015 ProStar with 217 miles on the clock.
Piece of cake.
VT
Originally Posted by glen e
Thanks Vegas Transplant. If you want to help that would be awesome. I don't have much for tools, just my "wax spreader" and my drill I use as a 3" rotary.
____________
You won't get far with those on such a large canvas.
If this is a working truck that criss-crosses I-70, then may I suggest the basic truck wash from Blue Beacon. Just add the acid option. For approx. $50 you can get it clay ready without the hassle or expense of doing it yourself. But of course you can de-con wash it yourself for around $20 but you gotta watch out for the glass.
Leaving sometime today for a four day class in Salisbury NC, followed by a week or so of on the road day trips to learn new employer methods and practices.
As for OTC metal polishes, I would go for heavy cut like Zephyr Pro 40 or White Diamond. Then follow up with Mothers.
As for the drill, you can use a small backing plate and pads from AG or maybe Harbor freight. I forget what they have. Those wheels will bling using elbow grease or machine http://www.autogeekonline.net/forum/...ng-polish.html
Will pm you before Friday. I want to send you samples of product to do various test spots at your leisure.
VT
Never seems like a good time to go to one when out and unloaded and keep my day as short as I can. Usualy anywhere from 8-14+ hrs sometimes when I'm working, and when at home a 2 and 4 yr old to help out with. Probably will wash myself when the weather warms up some. Pretty much in survival mode this time off year.
I found some Wab cleaning products at an International place near me. They have a couple high pH, two low pH cleaners, and a slightly basic truck wash. Not sure if they offer everything at the shop. I'm sure there is a bunch of truck supply places near me(70/81) just haven't looked.
Yeh, the Sears wax spreader was a lot of work but better than by hand. A lot of weight too. Had used #9 and the wax spreader on the other Frieghtliner we had. Worked two days on it, not non-stop or anything, maybe a real full days worth of work. Ended up looking decent.
____________
Long lines for sure. I hate waiting at these places.
I'm very unconventional myself. Mix my own acid to wash solution. Tuscarora Dave has a method where he chases an acid wash with an alkaline wash or rinse...i forget which. The tractor I just walked away from was washed weekly by me while waiting or during resets. Co. had Blue Beacon account which I did not use often.
Since this is not high priority til spring we'll get things figured out. I enjoy seeing classic tractors blinged out. My first Volvo tractor (co. issued) was about the time frame of your tractor.
Happy detailing...
VT
Yep, no rush. Way to cold around here right now with more great weather on the way. Will try to slowly get some supplies.
Thanks again for the info.
____________
By InfiniteShineDetail in forum Auto Detailing 101
Last Post: 10-19-2018, 06:30 PM
By Divine Details in forum Auto Detailing 101
Last Post: 08-14-2017, 08:03 PM
By Gearhead in forum How to make money detailing cars
Last Post: 11-03-2016, 05:35 AM
By JohnMcD348 in forum Auto Detailing 101
Last Post: 07-02-2013, 09:19 PM
By Hondaforlife954 in forum Auto Detailing 101
Last Post: 05-20-2012, 07:25 PM
26 | 27 | 28 | 29 | 30 | 31 |
