08-25-2012, 08:34 PM
#161
Re: Collinite #845: The Definitive How-To Guide For This Legendary Wax
I have a couple of questions about topping with Collinite 845.
I currently use WG FG 3.0 and finish the job with Fuzion. I have used this for a couple of years and really like the way my vehicles look. If needed, I will use the WG TSR 3.0, but that is normally about 1 time per year.
The last time I applied the WG Fuzion was about 4 weeks ago. I recently obtained a sample of the Collinite 845 product. I washed both vehicles last weekend and decided to apply the 845. The product went on very good and came off with no problems. I think it made the paint pop even more and when it rained the other day, the water just ran off the vehicles.
My questions are,
1.) If I follow my original steps listed above after removing the WG Fuzion, how long do I need to wait to apply the 845?
2.) Can I apply it in the same day just adding one more step?
3.) Can I go directly from the WG FG 3.0 to the Collinite 845 instead of using the Fuzion?
4.) Will the vehicle look as good? The paint is in very good condition.
5.) I know the 845 should/will last longer than the Fuzion; can I apply the 845 about every 10-12 weeks after washing the vehicle as long as the vehicle does not need the above mentioned steps? I stay away from car washes and the vehicles are in a garage every night.
Thanks,
Mike
User of Wolfgang and Pinnacle Products
1966 Sprint 200 Mustang - Sold
1970 Twisterspecial 428SCJ
1970 Mach One 428 Cobrajet
1972 Mustang - Sold
1973 Mustang - Sold
1985 MustangGT - Purchased new
1993 mustang LX 5.0 Vert - 9,000 miles
Looking for 1985 Saleen
08-25-2012, 09:00 PM
#162
845 is good enough to use without a sealant. I use it every winter and it does very well.
2014 Ford Mustang GT Track Pack-Black
2015 Chevrolet Silverado Crew Cab 4x4- Summit White
08-25-2012, 09:06 PM
#163
845 can last 4 months easily and likely longer unless you put your car through a fair amount of abuse. Try 2 layers of 845 and see what happens (just an idea). There is no cure time for TSR and FG; once you are done you can go straight to your LSP (845 or Fuzion).
08-27-2012, 06:53 PM
#164
Just got my bottle today, it's 100 degrees here in Los Angeles today and the heat had thankfully liquified 845 for me! hahaha
Back to the full-time grind.
10-02-2012, 05:49 PM
#165
Hi,
If the weather man is correct we should have a beautiful day tomorrow.Time to prep my SUV for the winter. Before proceeding I have five questions:
1- Does this product stains the trims?
2- I want to apply 2 thin thin thin coats is there a cure time between the two coats?
3- I want to use LC CSS grey pad to apply the wax using my Flex 3401 I'm I correct?
4-To buff the wax I was thinking using my PC 7424XP with a microfiber bonnet over the original backing plate supplied with the PC.?
5- Should I wax the entire car before buffing or work a little section at a time?
Thanks in advance for your answers.
Best regards,
Johny.
10-02-2012, 05:51 PM
#166
Hi,
Best regards,
Johny.
10-02-2012, 08:54 PM
#167
Can someone answer please?
Thanks.
10-03-2012, 10:19 AM
#168
Originally Posted by Johny B
Hi,
Best regards,
Johny.
FAQs » Collinite
That will answer some questions you have.
1. It's not recommended for trim.
2. If you look at the faq, it says to call them for cure times, even though two coats isn't necessary.
3. I used a gray ccs pad to apply mine and it worked great.
4. I like spraying quick detailer on it then buff it off with a soft mf towel, but there are many other ways.
5. This wax goes on so easy I'd just wax then entire car then come back and remove it after you've applied it to the whole car.
10-03-2012, 07:01 PM
#169
Thanks KillaCam. Job done today and was surprised how easy the Collinite Wax was to work with.I apply just one coat and topped it with Füzion.I am very happy with the result My car shines like a diamond and protected for several months.
Johny.
11-11-2012, 02:51 PM
#170
Just did my first coat of 845 yesterday. Very easy to use. Wondering if I could go over it today with Flitz Waxx Speed Wax, just to add another layer of protection? Thanks.
2019 Honda Civic Sport Hatch
2020 Acura MDX SH-AWD Tech
Last Post: 05-19-2018, 08:04 AM
By Mike Honcho in forum Auto Detailing 101
Last Post: 06-15-2017, 08:52 AM
Last Post: 03-08-2014, 10:33 AM
By jdmj0 in forum Auto Detailing 101
Last Post: 04-01-2013, 05:02 PM
Last Post: 03-22-2012, 09:55 AM
Members who have read this thread: 9
