Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    Mike Phillips
    Guest
    Tips for working in warm/hot weather or direct sunlight
    First the facts...
    Paint care products will always work best on a cool surface in the shade, this is true even for products that state they can be used in full sun. Even if a product can be used in full sun, working on a cool surface in the shade will always be easier and maximize the performance of the product because warm and/or hot temperatures, plus the heat from direct sun rays will always be trying to dry out your product before you can effectively work it over the surface.
    Also, there's a HUGE difference between working in full sun in the morning in a fall or winter month and working in full sun when working in August, in Arizona at noon on a black car. The temperature of black paint in August, in Arizona at noon can easily exceed 180 degrees and any liquid product applied to the paint will tend to want to dry very quickly even if on the label it says, "can be used in the sun" .
    A few tips...
    For those times when you don't have shade and it's warm or hot outside and you don't have a cool surface to work on, here are a few tips...
    Borrow some shade...
    First, look around and see if you can borrow some shade, by this I mean the shade created by a large building? Maybe under a large tree?
    Working under a tree can present a potential problem for debris falling out of the tree and on to your working surface but that's the trade-off for getting out of direct sun, so if you do work under a tree be sure to clean any panels immediately before working on them.
    Portable Canopy...
    If it's in your budget, invest in a quality EZ-Up type Canopy to create a shaded, protected work area.
    Shrink your work area down to a smaller size...
    Anytime a product becomes difficult to work with, one tip you can try is to shrink down the size of your work area. This means you spread the product out over a smaller area and only work this smaller area.
    Be careful not to allow yourself to do what I call Buffer Creep. This is where you creep outward from your original small section and end up buffing out a larger section. Avoid Buffer Creep. Especially if your product appears to be drying up and becoming dusty.
    Why a smaller area?
    Because when you're working only a small are you're continually engaging the working film of product over the area more quickly as you move the polisher and by doing this there's less time for the product to dry and dust.
    Clean your pads often or switch to a clean dry pad...
    It's vitally important to work clean and this means cleaning your pad often and often can mean cleaning your pad after each Section Pass no matter which type of polisher you're using.
    The definition of a pass
    There are two definitions of the word pass as it relates to machine polishing with any type of machine.
    Single Pass
    A single pass is just that. It's when you move the polisher from one side of the section you're buffing to the other side of the section you're buffing. That's a single pass.
    Section Pass
    A section pass is when you move the polisher back and forth, or front to back with enough single overlapping passes to cover the entire section one time. That's a section pass.
    YouTube Video on How To do a Section Pass
    In most cases if you're removing any substantial below surface defects you're going to make 6-8 section passes to the section you’re working before you either feel comfortable you've removed the defects or you're at the end of the buffing cycle for the product you're using.
    The warmer or hotter the temperatures and the worse the working conditions, then the more often you want to clean your pads.
    Rotary Buffers
    When cutting with a wool pad on a rotary buffer it really helps to have a pad washer, but if you don't have one you can get by with a Spur. When using foam pads you can use a pad washer or the "Cleaning your pad on the fly" technique" using a clean, terry cloth towel.
    How to clean your foam pad on the fly
    DA Polishers - Porter Cable - Meguiar's - Griot's
    When cutting with a DA Polisher you can get by with "Cleaning your pad on the fly"
    using a terry cloth towel, but a pad washer will clean a foam cutting pad better. Of course you can always switch to a new pad or a clean dry, used pad. The "Cleaning the pad on the fly technique" does not work with the Flex 3401 or the Cyclo Polisher. For these two types of polishers you'll need to use a pad washer, wash your pads by hand, or substitute clean new pads, or clean, dry used pads.
    Keep in mind that anytime you us ANY product that abrades the paint, you will have two substances building up on the face of your pad,
    1. Spent residue
    2. Removed paint
    Both of these need to be removed as they build up before adding new product and continuing with the buffing process.
    Back when cars were painted with single stage paints, you could easily see the removed paint build up on the face of the pad because it was pigmented or colored. This would be a strong visual indicator to help remind you to clean your pads often.
    With modern clear coats, you're still removing paint when you're abrading or doing correction work but because the clear layer is clear, it just doesn't show up as dramatically as single stage paint. The important point is to understand that clear paint is building up on the face of your pad and to clean our pad often.
    You also want to wipe off any residue from the area worked before adding fresh product if you're going to work the area again.
    Use an "ample" amount of product
    When I say use an ample amount of product this means don’t use too much product and don’t use to little product.
    From The Free Dictionary.com
    am·ple
    adjective
    1. Of large or great size, amount, extent, or capacity: an ample living room.
    2.
    a. Large in degree, kind, or quantity: an ample reward.
    b. More than enough: ample evidence.
    3. Fully sufficient to meet a need or purpose: had ample food for the party.
    Out of the above definitions, I'm using the 3rd definition.
    Using too much product
    If you use too much you can hyper-lubricate the surface and this will make it more difficult for the abrasives to abrade the surface as they’ll tend to want to glide or slip over the surface instead of bite into the surface.
    Using too little product
    If you use too little product there won’t be enough lubrication to enable the buffing pad to rotate and thus engage the abrasives against the surface so they can bite into and remove small particles of paint.
    You want an AMPLE amount of product when first starting out because you pad is dry and some of the product is going to seep into the pad leaving less on the surface to LUBRICATE and ABRADE the paint.
    Another option is to use a Pad Conditioner to lubricate and condition the surface of a dry pad, this will improve the buffing cycle and provide protection to the paint surface to help prevent micro-marring.
    XMT Polishing Pad Conditioner
    Cut down on the amount of product AFTER pad is broken-in...
    After your pad is broken in with product, clean your pad after each section pass and when you apply fresh product you can cut down on the amount of product you actually apply to the face of your pad.
    The key it to have enough product on the surface as you're working a section to have a film of product that you can see on the surface behind the polisher as you move the polisher in a direction.
    Start before the sun comes up...
    Do your machine compounding and polishing early in the morning when it's the coolest. Start setting up while it's still early in the morning while it's cool, then as soon as there's enough light to safely work, begin working the horizontal panels first. The reason for this is these will tend to get the hottest later in the day as the sun is over head making any correction or polishing work more difficult.
    When it comes to the vertical panels, you can usually move the car in such a way that the side you're working on is shaded to some degree by placing the sun on the opposite side, thus the surface temperature of the panel will be cooler.
    Use smaller, thinner pads
    The 5.5" pads are thinner than the 6.5" pads and should rotate easily with a PC 7424XP, Griot's Garage and Meguiar's DA Polishers under on the 5.0 to 6.0 Speed setting. Together with working a smaller size section and ample product this will make working on a warm or hot surface easier.
    Why to only work small sections at at time
    The larger the area you work the more the product is going to dry up on you because while you're working one portion of the area, the portions not being worked will tend to start drying via evaporation. By shrinking your work area down, shrinking your pad size down and using ample product you'll better be able to maintain a wet buffing cycle over a smaller area.
    Note: The larger the area you work the less abrading action each square inch of paint will get in relation to the time spent working the total area.
    Exception to the rule...
    While most instructions state to work a 2' x 2' area, when removing swirls in a warm or hot environment, it's usually more effective to work a smaller area.
    I tend to stick around the 20" squarish area and even smaller if the paint is harder, the swirls are deeper and it's extremely hot and windy as the heat and the wind together will both act to force your product to dry more quickly.
    Hope this helps....
  2. Thanks PM5C, RiverDog thanked for this post
    Likes PM5C, RiverDog liked this post
  3. #2
    SELF BANNED
    Join Date
    Feb 2010
    Posts
    498
    Post Thanks / Like
    Re: Tips for working in warm/hot weather or direct sunlight
    Never did like when a product claims how great it works in the sun
    .......... It ends up working ten times better in the shade.
  4. #3
    Super Member
    Join Date
    May 2010
    Posts
    295
    Post Thanks / Like
    I see another great invention in the future. The "Clean on the Fly MITT"! Who wants to take that bull by the horns! LOL I am unfortunate not to have a garage at my house, however I have plenty of large oak trees that love it when I park underneith them so they can spill their lovely sap onto my paint. I have been looking into the ez-up canopy's for awhile now. If anyone see's them on sale anywhere, online or stores, let me know. With my truck I don't think it's going to matter if it's a 10x10 or 10x20, she's a big truck and I'll have to move the canopy anyway.
  5. #4
    Super Member
    Join Date
    Jul 2007
    Location
    Stratford ct
    Posts
    969
    Post Thanks / Like
    ocean state job lot has them on sale this week
  6. #5
    Super Member AeroCleanse's Avatar
    Join Date
    Nov 2008
    Location
    Neenah, WI
    Posts
    2,422
    Post Thanks / Like
    Even with compound and polishers that work fine in the hot sun, make sure you don't get overheated.
    Shade works best for everything and everyone involved.
    Mike, what size Canopy is needed for detailing outside?
  7. #6
    Super Member Garry Dean's Avatar
    Join Date
    Jun 2009
    Location
    Tampa, FL
    Posts
    1,796
    Post Thanks / Like
    Nice piece of info, Mike. I have been dealing with this crazy humidity here in FL. Nothing works right. The sun is horrible when you have to detail and have to work in it, but a 10x10 gazebo really comes in handy unless its windy.
    Garry Dean - Tampa, FL - 813-846-4406
    Auto, Boat, RV, Motorcycle, Aircraft Detailing
    Premium Custom Detailing
  8. Likes RiverDog liked this post
  9. #7
    Super Member C. Charles Hahn's Avatar
    Join Date
    Aug 2007
    Location
    Lansing, MI
    Posts
    3,103
    Post Thanks / Like
    Excellent advice, Mike, but where's the section on avoiding heat stroke?
    I don't need clay lube in this muggy weather, the sweat dripping off of me is plenty sufficient!
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    http://www.cchautoappearance.com/
  10. #8
    Super Member trhland's Avatar
    Join Date
    Nov 2006
    Posts
    3,998
    Post Thanks / Like
    what i do is wait for the sun to go down. or park next to my garage its nice and shady there..
    names tom i live in nj with my wife cindy .and our 3 children. samantha gabriella and little tom...
  11. #9
    Mike Phillips
    Guest
    Quote Originally Posted by AeroCleanse View Post
    For most mobile detailers the limitations are determined by your work vehicle, that is how much canopy can you carry. And next is how much canopy can you put up by yourself.
    I used a 10x10 like the one here with the extra 3 walls that you can either use or leave off...
    After doing one end of a car or truck you can either pull it out, turn it around and put the other end in or leave the back wall off and drive forward to shade the next panels.
    I used 5-gallon buckets with water in them, (1-gallon = 8 pounds so a 5-gallon bucket with water = 40 pounds), hooked to the horizontal support with Bungee Cord, by doing this if any wind comes along it will lift a little and then settle back down.
    Quote Originally Posted by premium View Post
    See the post above and this one...
    Respect
    Quote Originally Posted by Shiny Lil Detlr View Post
    Good point, my normal habit is to take an ice chest with bottled water and a few Monster's or Rock Stars... it's important to stay hydrated...
    Quote Originally Posted by trhland View Post
    That's one option, by the end of the day the earth where you live has been heated by the sun all day, the air will be hot and it will be warm or hot outside.
    First thing in the morning the geographical land where you live and the air temperatures will have cooled down as much as is possible in the dark of the night and the morning temperatures will usually be cooler than the evening temperatures...
    It's all good if it works for you...
  12. #10
    Junior Member
    Join Date
    Apr 2013
    Posts
    59
    Post Thanks / Like
    All very good and notable suggestions. always be very considerate of the particular climate you are working in. sometimes I will have to turn a car around to face away from the sun and take a water drenched MG and drag it across the surface a few time to quick cool it back down before working on it.
    more important than what you are working on, everyone need to stay cognizant of their hydration level and symptoms of heat stress,cramp,stroke. which are exasperated by lack of circulating air and the accumulation of chemical fumes ( Read the MSDS)
Similar Threads
  1. Haze when in direct sunlight
    By pexle81 in forum Auto Detailing 101
    Last Post: 01-28-2019, 04:28 PM
  2. Direct sunlight ?
    By mikesal57 in forum Auto Detailing 101
    Last Post: 08-10-2013, 11:32 AM
  3. Wax for direct sunlight
    By Mercedes350 in forum Ask your detailing questions!
    Last Post: 05-26-2013, 09:28 AM
  4. Claying in direct sunlight?
    By Judge in forum Tricks, Tips and Techniques
    Last Post: 04-24-2013, 10:17 AM
  5. wdgps in direct sunlight?
    By unclestu in forum Auto Detailing 101
    Last Post: 11-17-2009, 04:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
