Re: Gg 3"
Originally Posted by Eldorado2k
That new 3" HD Backing Plate won't be compatible with the GG3. It's for the GG6.
I think that was meant for me to just get that for my GG6 instead of a new polisher.
Re: Gg 3"
Why would this not be compatible with the GG 3"? The thread size is the same. It simply seems to be more ruggedly constructed than the other Boss 3" plate, presumably to stand up to the extra abuse it will see from the 6" machine. I suppose it's possible that the rivet heads will contact something on the 3", but I'm guessing an extra fiber washer would fix that.
Gg 3"
From what I understand the thread size on the GG6 and the GG3 is not the same, so any backing plate that would fit the 6 isn't compatible with the 3 because the 3 uses a smaller spindle.
They made this beefy 3" HD backing plate in order to provide better cushion and stability compared to the typical 3" backing plates that are currently on the market.
http://www.autogeek.net/griots-3-inc...ing-plate.html
Sent from my iPhone
Re: Gg 3"
They are the same.
Re: Gg 3"
Where's Visitor?
Sent from my iPhone
Re: Gg 3"
Just to chime in...
I love the Griot's Garage 3" Mini Polisher.
I know scads of guys have dissed it over the years for not having enough power to remove swirls and they are right. It IS on the anemic side. --> It's also a LOT smaller than a full size tool and I think for at least some of these guys they simply have unrealistic expectations.
Here's the GOOD NEWS
Now that Lake Country has introduced the ThinPro line of pads, with VERY THIN foam pads, the tool rotates these LIKE CRAZY and this has transformed this to a functional tool. Now a year later Griot's is introducing their own THIN pads and like the LC ThinPro pads they rotate like crazy.
So get one.
I'll be demonstrating this tool for both machine sanding and removing sanding marks all weekend at MTE.
Here's pictures of the pads...
NEW! 3.5" ThinPro Foam Pads! Thin is in and you're going to love these new small foam pads!
MORE IMPORTANT - if you click the link, read the words and look at the pictures you'll see Jeff Bell aka GSKR machine SANDING with the Griot's 3" Mini Polisher and then using the SAME polisher to remove his sanding marks at one of my Thursday night classes.
Hope that helps and don't listen to the scads of naysayers that have not used this tool with the LC 3.5" ThinPro pads...
Watch out for the gray pad, it's a cutting son-of-a-gun....
Re: Gg 3"
Where's Visitor?
I shipped out 4 Griot's Garage 3" mini polishers to use on the two project cars for the TV show.
Re: Gg 3"
IMO it was the advent of MF pads that made this tool useful (other than for sanding). But it's great that there are more foam options now, especially since Meg's stopped making their 3" MF pads.
Mike, perhaps you can settle the thread size issue for this machine and whether that heavy-duty 3" plate for the GG 6" will work on the 3".
Gg 3"
Looks like I was wrong about the thread size being different, but this new HD backing plate isn't recommended for the GG3 because it's too beefy.
Kinda like putting these tires on a Smartcar. Lol.
Sent from my iPhone
Re: Gg 3"
I agree. From August of 2010 - about 7 years ago...
1954 Ford F-100 - Extreme Makeover - Process and products used
This is me tackling the iconic front grill using the Griot's Garage 3" Mini Polisher using an Optimum 3.25" Microfiber Pad with Hyper-Polish.
I now the question everyone wants to ask and here is the answer...
YES the 3" Mini Polisher was able to maintain pad rotation. I started with the upper potions and worked downward and wiped the residue off as I worked... look how shiny and glossy the paint is after using the 3" Mini Polisher. The 3" Mini Polisher also makes a great Dampsander for spot repair.
That was back when we had the Swirl Girls...
1954 Ford F-100 - Modeled by Janna
Yes it will fit.
The new 3" HD Griot's backing plate uses the same 5/16" thread size in the spindle that the full size Griot's uses as well as the Porter Cable and Meguiar's MT300
Note: I would not recommend using the Griot's 3" HD backing plate on the Griot's 3" Mini Polisher as it's TOO heavy duty meaning it has too much mass and weight. It's my opnion that the extra mass and weight will wear out the bearing that supports the spindle in the Griot's Garage 3" Mini Polisher prematurely. The bearing already wears out and I told this to Jeff Brown at SEMA. If he doesn't see this thread I'll do a follow-up e-mail to him as this is the weak point of the tool.
Hope that helps...
By denns1989 in forum Show N' Shine
Last Post: 01-15-2018, 08:22 AM
By hardrock2401 in forum Product Reviews
Last Post: 09-20-2015, 07:11 PM
Last Post: 04-11-2014, 09:21 AM
By zckid in forum Show N' Shine
Last Post: 12-21-2013, 11:16 AM
By IID in forum New Car Care Products
Last Post: 10-08-2012, 12:59 PM
