Results 1 to 8 of 8
    Junior Member master_photog's Avatar
    Nov 2011
    55
    newer boat - best for removing water spots?
    I'm close to finishing my bottle of Collinite 840 which is what I've mostly used on removing my water spots on the gel coat of our 2015 boat.
    It's done a pretty decent job, although it does take a good amount of elbow grease when doing it by hand.
    I'm curious if anyone has used any other products that do an equally good job or better with a little less work than the Collinite 840?
    Thanks!
    Super Member Rsurfer's Avatar
    Jan 2007
    14,111
    Re: newer boat - best for removing water spots?
    Quote Originally Posted by master_photog View Post
    Thanks!
    Get a DA polisher. You also have cars don't you? Doing it by hand is like having a land line only.
    Super Member VISITOR's Avatar
    May 2007
    9,783
    here's a line of products specifically for boats.
    call nick, i'm sure he'll be more than happy to assist in any questions you may have...
    Marine31- Boat Waxes, Cleaners & Polishes
    1-877-797-8803
    Jul 2017
    I've used use white vinegar and water 50/50; Boat Bling Hot Sauce; Meguires Hard Water Spot Remover; and Babes Spot Remover, and they all worked fine for run-of-the mill hard water spots on gel. Now I wipe the boat down with Babe's Boat Bright pretty much every time I pull it (I trailer for every use) and have not had any water spots to remove in a while.
    Feb 2015
    Ft. Lauderdale,Fl
    615
    I use an acid based product if they are bad. Lot less work and it's ready for wax after that.
    Jul 2017
    There is a product called "Boat Bling Hot Sauce". When I purchased a new seadoo we went out to a lake that had lots of minerals in the water and what was once a new ski looked like it sat outside for a year. I was beyond upset and nothing was making it better. I found this stuff on another forum and gave it a try. The first time you might have to go over it twice but after that, its a piece of cake. I used it now after each ride and the ski looks new again.
    Nov 2013
    110
    Muratic acid bath
    Dry
    Alcohol whip down
    Dec 2006
    798
    FWIW, I've had really good luck with Mother's Cleaner wax on hard water spots. So good that one time I got a rental that was hammered with some too, figured it couldn't budge them, I was wrong. I've tried all sorts of other products, not much luck with others, DG501 was even marginal in that respect.
  1. Removing Water Spots
    By lightsout66 in forum Auto Detailing 101
    Last Post: 05-12-2018, 11:09 PM
  2. Help Removing Hard Water Spots on Boat
    By malibuboats91 in forum Boat & Marine Craft Detailing
    Last Post: 06-04-2014, 08:10 AM
  3. help removing water spots
    By cadd in forum Auto Detailing 101
    Last Post: 01-05-2011, 10:55 AM
  4. Removing Water Spots - Very Old Car
    By rmmagow in forum Ask your detailing questions!
    Last Post: 01-03-2010, 05:23 PM
  5. Removing Water Spots
    By dsyukon in forum Show N' Shine
    Last Post: 08-19-2006, 09:09 AM
