» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Senior Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    3,128
    Re: Moderate Boat Oxidation. Wetsand or Buff?
    I just did an 87 FourWinns 195 that was white, light blue, and darker blue. I would say it was probably somewhere near what you are describing 6-8 bad. Flex and yellow cutting pad with McKees RV heavy cut wouldnt touch it, Wool pad on HF rotary and same compound did a pretty decent job (maybe 70-75%) and still took me some good time. If you have the sanding ability and equipment I would suggest it. Make sure you charge plenty too lol.
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
    Senior Member Markymapo's Avatar
    Jun 2018
    Audubon,PA
    294
    Boat looks good. Luckily the Cobalt is my boat(6 years old n a. BIt neglected so now in recovery mode. The interior seating n top fiberglass are in excellent shape Been buffing cars now tackling boats so use mine to practice. Hooefully i can take one if Mikes classes in the future on gel coat work
  3. #13
    Jun 2009
    Stuart, Florida
    43,961
    Quote Originally Posted by PursuitDT View Post
    Hey guys/gals,
    I inspected a 22ft Four Whinns H210 today for a new client of mine. It has moderate oxidation on the upper portion of the black paint. It's black with a white top. Wish I had photos to share, but that was my mistake. I'm trying to figure out the most efficient way to go about doing this.
    Scale 1-10 (10 being really bad)
    I would say its a 6-7.
    1. Do I wetsand the gel coat down to eliminate the oxidation?
    Or
    2. Do I buff out the gel coat with my D/A and MF pads? (Keep in mind I do not own a rotary)
    I'd like to see if I can get Mike's input on this!
    Hope for some feedback.
    Thanks.
    Not that you can't bring an old thread back to life, but the above was posted,
    05-06-2017, 04:54 PM
    Quote Originally Posted by Markymapo View Post
    Very useful. I have Cobalt 242 that is 6 years old and has moderate oxid (6/7 out of 10)Tried using my flex 3401 with compound/ wool pad test spot (result = it will take me until Christmas 2019 to get it done).
    Looks like I either wet sand it or get a rotary n hit with wool/compound.
    Will do a wet sand with 3000 grit (least aggressive) using my 3401 and see what happens. Been reading Mikes book n am leaning toward sanding
    Here's the deal.... oxidation tends to go INTO the gel-coat so when gel-coat has visible oxidation buffing the surface will restore the shine but it will tend to revert back fairly quickly. Machine sanding will remove all of the oxidation and the results will last longer.
    If it's not to bad, then possible Mirka Abralon with #3000 followed by #4000 and then Captain's Compound with a rotary buffer and wool pad. Follow this with the RUPES blue foam coarse pad and the same compound. Then chemically strip and apply Gtechniq C1 Crystal Lacquer.
    See picture here,
    BEFORE & AFTER - EXTREME Gelcoat Oxidation Removal + Ceramic Coating
    See how we did it here,
    Pictures: 2018 Boat Detailing Class at Autogeek with Mike Phillips
    Next class is February, 9th and 10th 2019 and it's already filling up.
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Files YouTube Playlist
  4. #14
    Jun 2018
    Audubon,PA
    294
    Learned my lesson not hitting my boat with more passes during wet sanding with 3000 grit thinking I could get the remaining with wool n Captains one step compound n polish. May try 2000 grit followed by 3000, then wool, then polish (test spot). So wanted to take Mike,s class this past winter but my job sent me To China at the same time as his class( the trip was well worth it as I work on developing Oncology drugs). Maybe 2020 I can make the class
    2018 CaymanS, 2016 BMW M4
    2015 Lexus IS 350
    2016 Ford F150
  5. #15
    Jun 2018
    Audubon,PA
    294
    I ended up going down to 2000 grit, followed by 3000 then wool then foam pad , wow what a work out and still have another side of the boat to do. Just for fun I hit a section with 1000, then 2000, then 3000 then wool then foam pad, but that’s a lot of work. Thanks for the input
    2015 Lexus IS 350
    2016 Ford F150
  6. #16
    Feb 2014
    Any suggestions for a non skid gel coat surface that is oxidized? It could definitely use some sanding, but the “non skid” is gel coat in the shape of little waves (blue wave pure bay 2400) so sanding would actually damage the non skid. I’ve had amazing results using presta compound, but I’m worried about long term correction and I definitely don’t want to keep going through this.
  7. #17
    Jun 2009
    Stuart, Florida
    43,961
    See my reply to your thread.
    There’s 3 commonly used types of non-skid
    1: Molded-in = gel-coat
    2: Painted.
    3: Sundeck (could be wrong on this word, I don’t have my book in front of me)
    You can machine scrub molded-in as this is gel-coat and it’s tough.
    Twitter
    Instagram
  1. Preferred methods for romoving light to moderate oxidation...
    Last Post: 09-09-2018, 07:44 PM
  2. Pictures: 2017 Marine 31 Boat Detailing Class - 25' Bluewater Center Console - Wetsand, Cut & Buff
    By Mike Phillips in forum Boat Detailing Classes Dates and Info
    Last Post: 02-03-2017, 04:42 PM
  3. How to wetsand, cut and buff a gel-coat boat
    By Mike Phillips in forum Pictures from Wednesday Night Projects
    Last Post: 07-09-2014, 11:02 AM
  4. new to boat detailing need advice on boat with extreme oxidation
    By shaffer in forum Boat & Marine Craft Detailing
    Last Post: 05-17-2014, 10:51 PM
  5. Will a wetsand and buff do the trick?
    By heyhi in forum Wet-Sanding, Cutting & Buffing
    Last Post: 03-17-2012, 10:29 PM
Members who have read this thread: 30
» November 2019
2728293031 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
