Re: how many of you are using microfiber pads as a one step?
ive used the megs cutting pad with megs UC on my green 99' expediton. LSP ready after that
I know this is a one step thread but having said that on a side note...You can indeed finish down with great results using MF finishing pads particularly the Megs pads on any paint.
The trick is very slow arm and rotation speed. I'm talking having the pad just barely rotating. The slowest speed you can set on your DA with the pad rotating.
Then slow arm speed down and the most important thing is you must, must , must ...keep the pad clean by blowing it with air after every panel.
Also once you initially prime the pad, use very little product for each section after the initial prime. I'm talking two small pea size drops per section.
In summary
-Prime pad initially
-Two small pea size drops henceforth
-Slowest rotation speed possible to maintain pad rotation
-Very slow arm speed
-Clean clean clean the pad after every section
-Use Megs finishing pad. They have been much improved since inception.
Originally Posted by hernandez.art13
I use foam pads to finish with they work a lot better to finish with.
Originally Posted by Pureshine
What kind of car is this? Perfect results as expected from you. Is that a 1/4" tape on the door edge?
I am wondering what you guys think about what Larry from Ammo said that he uses MF pads for cutting and foam pads are for polishing. (Something like that)
He says it staring at 12:00
http://youtu.be/2CmhFe1r3rk
Larry knows his stuff, I use the same method.
Last Post: 05-12-2020, 10:34 AM
By Billy Baldone in forum Auto Detailing 101
Last Post: 10-21-2018, 08:11 PM
By Cruzscarwash in forum Product Reviews
Last Post: 09-30-2018, 01:12 PM
By SalFoges in forum Auto Detailing 101
Last Post: 04-21-2012, 06:49 PM
