Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Super Member Marc08EX's Avatar
    May 2008
    4,108
    How To Remove Rupes Polisher's Factory Backing Plate Bolt
    Do you have a Rupes 21ES polisher and you want to switch out your factory 6" BP to the 5" BP? Or do you have a Rupes 15ES and just want to replace the BP? But wait there's a problem... How in the world do you get that tight-a$$ factory bolt out?!?! Not unless you have big guns like Mark, this bolt is so hard to remove!!!
    I thought I was extremely weak for not being able to remove it myself but someone PM'ed me who experienced the same problem. So there might be more people experiencing this. Therefore I decided I would like to share how I removed that tight factory installed bolt holding the backing plate.
    The leverage from the allen key provided by Rupes wasn't enough. So I used this set of pliers:
    I just clamped on the allen key sitting horizontally increasing the leverage on the allen key. Just twist it and viola!!! It will come off.
    Here are other types of pliers you can use:
    Hope this helps!!!
    Super Member zmcgovern45's Avatar
    Sep 2012
    St. Louis, MO
    3,443
    Re: How To Remove Rupes Polisher's Factory Backing Plate Bolt
    Weird, mine was easily removed with just the provided allen key.
    Retired Professional Detailer
    Super Member CWallace's Avatar
    May 2012
    247
    thought mine was defective, cause the screw was so hard to get loose!!!!!
    Super Member Rsurfer's Avatar
    Jan 2007
    14,111
    Mine was welded on, at least it felt that way.
    Super Member BucboyInPa's Avatar
    Dec 2011
    Mechanicsburg,Pa.
    324
    I had to take mine to a friends motor shop,and even he had a hell of a time getting the bolt loose.
    Super Member BobbyG's Avatar
    Dec 2009
    Southeast, MA
    13,211
    The first question that comes to mind is why this bolt is installed so tightly at the factory?
    Super Member mrGolfRider's Avatar
    Apr 2009
    Fairfield Township, OH
    244
    This thread has made me feel so much better. I ended up using the closed end of a wrench for more leverage. That bolt is excessively tight from the manufacturer.
    Matt Ferguson
    Needed Touch Detailing
    Making the city shine, one car at a time.
    Dec 2009
    Southeast, MA
    13,211
    Did anyone notice a thread lock compound on the bolt once it was removed?
    May 2008
    4,108
    So how did you guys get it off?
    Quote Originally Posted by BobbyG View Post
    I didn't Bobby. What does it look like?
  10. #10
    Super Member poweraid's Avatar
    Mar 2011
    wausau, wisconsin
    1,046
    most thread locker is blue or red in color
  1. RUPES 2" Backing Plate not for use with the rotary connector and the RUPES Nano iBrid
    By Mike Phillips in forum RUPES BigFoot Oribital Polishers
    Last Post: 01-22-2017, 10:37 AM
  2. Replies: 7
    Last Post: 09-18-2016, 06:32 PM
  3. Rupes 15 vs Rupes 21 w/5" backing plate
    By expdetailing in forum RUPES BigFoot Oribital Polishers
    Last Post: 12-02-2014, 11:52 AM
  4. How do you remove the backing plate from the Rupes Bigfoot 21?
    By Calendyr in forum Ask your detailing questions!
    Last Post: 09-18-2013, 10:06 PM
  5. Flex XC3401VR Backing Plate Allen Bolt??
    By ehuth1 in forum Flex Polishers
    Last Post: 05-24-2010, 01:05 PM
