Drying a coated car??!
I have searched the forum for an answer to this question, if this has already been answered please direct me there. Thanks!
How do you guys dry a coated car?
I find that most coatings are so hydrophobic that the water slides right off and even sometimes I wipe a dry microfiber on dry paint. The water doesn't "absorb" into the paint like it seems it does without a coating, the water tends to either sit and streak, or dry so quickly I am afraid I am doing damage by drying.
My solution has been either a spray detailer or 50% distilled water and 50% alcohol sprayed into a MF towel, but I'm not sure that's the best or safest solution. it's an extra step which can Ben time consuming.
What do you guys do?
Thanks for the help!
Re: Drying a coated car??!
I use a Metro sidekick to blast the little bit of left over water away. If you are looking for a drying aid that won't alter the coating's characteristics, get some meguiars d114 and dilute 1:256
Damp waffle weave MF towel.
1 damp drying towel followed by a dry towel. You can use whatever detailer is recommended by whatever coating you have as a drying aid. Check out Kamikaze overcoat also, designed to be used over coatings for that purpose also.
I blow dry, then blot any remaining water with a waffle weave. Flood/sheeting method works as well but uses a lot of water, again follow-up by blotting.
I lay my large waffle weave over a section make sure it's completely flat then remove. Water is gone. Sometimes I use a leaf blower to dry it.
I use the sheeting method to remove most the water from the vehicle. Then a MasterBlaster is your friend. It makes short work of drying a car and blowing out your nooks and crannies.
I have the little sidekick too. Bought it for my motorcycles and love it for the autos.
As others have said. I sheet water then vac&blo followed by a damp WW towel for the runs.
Great idea!
Never thought of that one.
By Route246 in forum Auto Detailing 101
Last Post: 05-12-2018, 09:09 PM
By geoguy in forum Auto Detailing 101
Last Post: 11-16-2017, 10:04 PM
By Harry Da Hamster in forum Auto Detailing 101
Last Post: 09-17-2016, 03:22 AM
Last Post: 02-24-2014, 11:57 AM
By octane in forum Auto Detailing 101
Last Post: 11-12-2012, 04:26 PM
