removing dry polish from paint
Hey guys,
What's the recommended method for removing dried up polish on the surface paint that has dried up. This is predominantly around the edges around the sunroof, door ttip , but still on paint and not on any vinyl or plastic. I plan on washing, claying, and sealing my paint for the upcoming winter season but I would like to remove some old left over polish residue before I do this
Thanks guys
Re: removing dry polish from paint
I usually wipe off old, dried polish and/or wax with a microfiber towel slightly dampened with isopropyl alcohol.
Sent from my N9810 using AG Online
Would I was the car and then do an IPA wipedown? Also, it seems as though using alcohol on car paint isn't the best for it, is there a better alternative such as maybe claying it again after a wash?
If it's polish and not wax, then a diluted version of Meguiars Rinse Free Express Wash (D114) is excellent when used with a microfiber. If it's been on there a while, then you may need to step it up to a diluted IPA.
Hey jarred, thanks so much doe the tip. Is there an alternative that might be available on eshine.ca as they don't sell the meguiars free rinse?
Thanks again
I use a fingernail covered by a MF towel to get into the little cracks and crevices and if need be, I'll use a bit of quik detailer to soften the dried wax.
Don,
Would you just agitate the MF towel with your fingernail until it is gone? Would you step it up to IPA wipe down if it doesn't work? And after you let it soften for a while, would you then proceed to wash the car?
Originally Posted by wssviper
Don,
I don't really like doing an IPA wipe down, no reason, it's just not my thing. If using the fingernail in the towel trick doesn't work, I'll move on to a soft (or well used, no good for teeth anymore) toothbrush and the QD. There are all sorts of "tools" (Q-tips, cotton balls, horse or boar's hair brushes etc) you can use to get in those tight areas, just make sure you use plenty of lubrication (soap or QD) to help prevent scratching. THEN after getting that done, I would wash the car to flush out all the gunk I removed from where I was working.
I would not recommend using a tooth brush on any painted automotive surface.
What would you recommend as an alternative?
By Tim711 in forum Ask your detailing questions!
Last Post: 01-01-2018, 06:19 PM
By Scott@IncrediblyDetailed in forum Ask your detailing questions!
Last Post: 04-11-2014, 06:55 AM
By 2shiny in forum Ask your detailing questions!
Last Post: 09-18-2013, 06:52 AM
By Kitoy22 in forum Auto Detailing 101
Last Post: 04-23-2012, 07:49 AM
By shadybreal in forum Auto Detailing 101
Last Post: 02-11-2008, 09:00 PM
