When to use IronX?
Would I use IronX before or after I clay the car?
Thanks
Re: When to use IronX?
When introducing new products and processes into your routine, it helps to think about the process logically...
Consider the purpose of both IronX and detailing clay. IronX is used to remove bonded iron particles. Detailing clay is used to remove all bonded contaminates.
If you were to use Iron X after claying, there would be very little (or hopefully no) iron contaminates remaining for the product to remove. With that being said, it would make most sense to use IronX first to eliminate the iron particles before claying, thus leaving less contamination for you to remove with the clay bar and therefore (hopefully) saving you time using the clay bar (or synthetic clay substitute).
Retired Professional Detailer
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by zmcgovern45
Well said.
Thanks everyone I just wanted to check with the experts as I am new to a lot of these products.
Thanks
There's one very important reason left out....
The reason you want to use Iron X first is to dissolve any iron particles before you clay the paint or use any other mechanical means to decontaminate the paint.
The reason why is because if there are iron particles in the paint, if you use clay and successfully pull out or pull off these iron particles onto the clay, you now risk rubbing these iron particles over the paint instilling scratches.
Been there done that one time in my life.
So chemically decontaminate first and then mechanically decontaminate.
a little tip, using a pressure sprayer uses very little product and even coverage
By Route246 in forum Auto Detailing 101
Last Post: 08-28-2018, 04:46 PM
By TuxedoTaurus in forum Auto Detailing 101
Last Post: 07-17-2014, 07:22 AM
By canairb in forum Auto Detailing 101
Last Post: 05-04-2014, 04:30 PM
By Avi@CarPro in forum Auto Detailing 101
Last Post: 04-02-2012, 11:25 PM
Last Post: 04-17-2011, 03:19 PM
26 | 27 | 28 | 29 | 30 | 31 |
