Results 1 to 6 of 6
    Newbie Member ssdx's Avatar
    Apr 2014
    370z, having issues using griots one step / griots DA
    So, i've got these buff marks left behind by my polisher. I washed the car with Dawn to strip what wax was left, clay barred using griots clay and speed shine, then hit the whole car with a griots(everything is griots btw) orange pad and machine polish 2, which took a ton of the swirls out. still have super thin scratches but anyway. then i started using their One Step sealant with the orange pad, and come to find out half way through, its leaving behind a slight haze and these buff marks (see pictures below) which some i can remove with speed shine and some i cant. i searched around and figured the pad was too abrasive. this even happened with a clean pad, btw. so i went back to griots and grabbed their black polishing pads.. it helped for sure, but i can't get some of them out. is this normal? is it too much oil in the one step? i have half a bottle left and have no idea how much it was shaken during use last time the bottle was used. I tried finding megs 205 locally since one of the employees at griots said it may just be my paint, and megs 205 is what they needed to use as a finisher on some cars. any idea what is causing this? is it a cause for concern? and any recommendations to avoid them? its very frustrating because I have a magazine shoot tomorrow and im stressing out over it.
    any info would be greatly appreciated...
    Steve
    2011 Solid Red 370z "Zleeper" - 474whp
    2013 Ingot Silver Focus ST.. the daily
    Super Member artofdetailing's Avatar
    Sep 2010
    Potomac, Maryland
    437
    Re: 370z, having issues using griots one step / griots DA
    Never seen that before. Did you apply the sealant with a waxing pad and on the lowest speed setting?
    Brian Dubinsky
    ELITE: Luxury Detailing + Paint Protection
    Maryland - Northern VA - DC
    Super Member HD.Detailing's Avatar
    Jan 2014
    Indiana
    928
    My z has soft paint so orange pad too aggressive for sealant... which you already know. White pad 205 should clean that right up.
    Sent from my Alien Ship
    Super Member spiralout462's Avatar
    Dec 2012
    Eastern Shore, VA
    1,771
    I would try a less aggressive combination of pad, product and technique. Do you have a finer polish or foam pads from other manufacturers? I find it interesting that the Griot's employee recommended M205. Did you prime your pads?
    http://www.autogeekonline.net/forum/...test-spot.html
    http://www.autogeekonline.net/forum/...ing-guide.html
    http://www.autogeekonline.net/forum/...-polisher.html
    Aug 2010
    New Jersey
    15,173
    That just looks like product residue. Sometimes AIO's (All-in-one's) like you're using can be gummy by machine (especially if you use too much). Do you have a fine Griot's polish that you can use, and apply a glaze or wax or sealant by hand after?
    Apr 2014
    Thanks guys, seriously for replying so quickly. I did read on how to prime the pad today, and it's a fresh pad.. the black, finer Polishing pad, one step above their red wax pad. I do have their paste carnauba wax to apply by hand after. I've slowed down my movements, and I'm running the machine on 3. It seems to be getting the little leftover scratches out and doing a good job, just the residue or whatever left behind. I also am using more pressure, and I've actually been getting the residue off almost completely using the speed shine after.. just hope my wax will stick. I don't have any other finer products or pads to use on the machine unfortunately..
    The reason the employee said to try the M205 if the finer pad didn't work was due to it being a synthetic and that it may work better on the soft paint
  1. ATS V vs Griots One Step Sealant
    By Cadillac Hunter in forum Auto Detailing 101
    Last Post: 09-13-2020, 08:38 PM
  2. 3" griots garage pad issues?
    By bossmustang16 in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
    Last Post: 03-13-2016, 01:07 AM
  3. Griots Garage glass polish issues.
    By choijw2 in forum Ask your detailing questions!
    Last Post: 01-12-2016, 09:51 PM
  4. 3" griots garage pad issues?
    By bossmustang16 in forum Wool & Foam Buffing Pads
    Last Post: 02-06-2015, 10:58 PM
  5. Griots One Step Sealant
    By BTLew81 in forum Product Reviews
    Last Post: 11-12-2012, 08:34 PM
