Go Back   Auto Geek Online Auto Detailing Forum > Detailer's Library > How to Articles
» Autogeek Online Classes
Reply
Thread Tools Display Modes
Old 04-29-2011, 12:13 PM   #1
Director of Training
Mike.Phillips@Autogeek's Avatar
How to prime a foam pad when using a DA Polisher
Here are 3 ways to apply product to your pad.
1. Priming the pad then adding product to work with
Priming a clean, dry pad is considered the best approach for using a DA Polisher because it ensures that 100% of the working surface of the pad is wet with product and working at maximum efficiency when you turn the polisher on. I originally learned of this technique from my friend Kevin Brown.
Priming the pad also ensures that you don't have any dry portion of the pad working over the paint un-lubricated. This really isn't a risk because since you're just starting out you're going to be removing defects a lot more serious than would be caused by any portion of the pad that is dry and spinning against the paint.
Plus, after just a few passes, the product you apply to specific areas of the face of the pad will migrate over the entire face of the pad and it will do this rather quickly when you're on the higher speed settings.
Priming the Pad - For clean, dry pads
Start with a clean, dry pad and add some fresh product to be spread out to the face of the pad. Using your finger, spread the product out over the pad and then using your finger work it into the pores of the pad. Don't saturate the pad, just use enough product to make sure that 100% of the working face of the pad has product coverage.
Work the product around the face of the pad and into the pores
Any extra, take and apply to the outer edge until 100% of the working face of the pad is primed with product.
As an option you can also prime the outer edge. This helps if you're buffing around convex curves or around panels that the edge of your buffing pad may come into contact with, like spoilers, side mirror housings, curved panels etc.
Primed and ready to add "Working Product" to.
Adding "Working Product" to the primed pad
Some people will recommend 3 to 4 pea size drops of product as the proper amount of product to use and this can be correct for concentrated products or working small sections and if you follow this advice make sure you are not under-lubricating the surface being worked.
Pea size drops of product
For some products and paint conditions, you may want more product on the surface working for you. Here's an example of dime size drops of product.
Dime size drops of product
How much product to use after priming
Ample
You want an AMPLE amount of product when first starting out because you pad is dry and some of the product is going to seep into the pad leaving less on the surface to LUBRICATE and ABRADE the paint
Cut down on the amount of product AFTER pad is broken-in...
After your pad is broken in with product, clean your pad after each section pass and when you apply fresh product you can cut down on the amount of product you actually apply to the face of your pad.
Too Little Product
Under-using product reduces lubricity and will make it more difficult for your pad to rotate efficiently.
Too Much Product
Using too much product will hyper-lubricate or over-lubricate the pad and will interfere with the abrasives ability to abrade the paint.
Keep in mind that you want enough product on the surface so you have,
  • Abrasives working for you.
  • A lubricating film between the paint and the pad.
Often times if you don't have enough product to work with you'll end up buffing to a dry buff. When you lose lubrication, friction increase and this can lead to micro-marring or hazing.
2. Applying a Circle Pattern of Product
Benefits to a Circle Pattern
As you work around the car you'll find that your product will migrate to the center on it's own. This can lead to pad saturation starting at the center of the pad where most of the heat is generated.
This can cause problems because wet foam will hold in heat better than dry foam and over time this can accelerate de-lamination between the hook & loop material and either the foam of the pad or the backing material on the backing plate.
Knowing this... I don't help the problem by using an X pattern as using an X-pattern means putting product onto the middle of the face of the pad.
If you're placing pea or dime sized amounts of product to the face of your pad then it's also a good idea to avoid placing the product directly in the center of the pad.
Circle Pattern on a clean dry pad and then worked for a Section Pass
After working the circle of product over a section, you can see it spread the product out over the entire face of the pad without having to spread it with your finger. The pad is now equally primed with residual product.
Cut down on product after your first section pass
At this point you could clean your pad or add fresh product and when you add fresh product you can adjust how much product you apply.
In this example I used half a circle of product since 100% of the face of the pad is now primed from the previously applied and worked product.
3. Applying an X-Pattern of Product
Applying your product to the face of your buffing pad using an X-pattern is a fast and simple way way to get product out of the bottle and onto the pad in a measured way that's easy to teach others and a method that's easy to duplicate over and over again.
X-Pattern on a clean dry pad and then worked for a Section Pass
After making a thorough Section Pass. The pad is now equally primed with residual product. At this point you could clean your pad or add fresh product and when you add fresh product you can adjust how much product you apply. In this example I used half an X-Pattern, or a single strip of product since the pad is already primed.
Wet Buffing Technique
Maintain a wet film on the surface
The key is to have enough product on the surface as you're working a section to have a wet film of product that you can see on the surface behind the polisher as you move the polisher over the paint.
Options
Pad Conditioners
Another option is to use a product called a Pad Conditioner to lubricate and condition the surface of a dry pad. This will improve the buffing cycle and provide protection to the paint surface to help prevent micro-marring during the initial break in of a dry pad. This will also make cutting pads which are usually very stiff and aggressive when dry more pliable to conform to the contours of body panels.
XMT Pad Conditioner
Mike.Phillips@Autogeek is online now
Old 04-29-2011, 12:35 PM   #2
silverfox's Avatar
Re: How to prime a foam pad when using a DA Polisher
Again, a GREAT article by Mike...
__________________
My name is John. In my day we didn't have the Internet, iPods, or cell phones....but we had some really bad-azz cars.
silverfox is offline
Old 04-29-2011, 12:48 PM   #3
BobbyG's Avatar
Two things that come to mind are; beginners at both detailing and online forums such as Autogeek Online.
There are literally so many products, accessories, options, and uses even some of the mores experienced in detailing can be overwhelmed. This combined with what seems like a never ending stream of instructional sections covering every facet of this art will leave even the most brave at heart humbled.
Mike,
I think it's a great idea to breakout topics like this and post them separately for users to easily find and absorb...
__________________
BobbyG is online now
Old 04-29-2011, 12:49 PM   #4
sohail99's Avatar
Great tips!!
sohail99 is offline
Old 04-29-2011, 12:55 PM   #5
don083's Avatar
Thanks Mike for yet another great article, the best thing I learned from this is to not use as much product when moving on to another section pass, i will save money on product and maybe get better results from the pad working.
don083 is offline
Old 04-29-2011, 12:55 PM   #6
LegacyGT's Avatar
Great pictures, especially the close ups!
__________________
Detail Fest 2012 Face Book Page
Club Flex 3401/PE14-2-150
-Bill
LegacyGT is offline
Old 04-29-2011, 01:51 PM   #7
MonoPed's Avatar
Great info - thanks Mike!
__________________
Brian Fowler, Hernando, FL
2008 Mustang Pony Package
MonoPed is offline
Old 04-29-2011, 04:26 PM   #8
Bunky's Avatar
I am not a regular polisher but in my last uses with Menzerna I just primed the pad with about 2x my next section amount. I spread it around by finger and then attempted to spread on paint. If it could not cover the work area I added a couple dabs more. I found this technique to not over prime the pad (been known to do that) so it takes forever to get the initial section to break down. There is minimal risk of under applying since you will notice during the spreading pass. The worse that should happen is it flashes too quickly but this is easily fixed.
__________________
Al
The Need to Bead
Bunky is offline
Old 04-30-2011, 06:40 AM   #9
Thanx Mike!
Bill
BillE is offline
Old 04-30-2011, 07:39 AM   #10
mdb917's Avatar
Great explanation.
As BobbyG stated for a newbie the choices are seemingly endless and overwhelming. When you take a focused approach to explaining a relatively simple part of the process it is invaluable. My take on it anyway.
Thanks Mike P.
Mike
mdb917 is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
The Cure for M105's short working time and dusting issues Lasthope05 Auto Detailing 101 113 05-10-2012 01:33 AM
How to MAXIMIZE your DA Polisher Mike.Phillips@Autogeek How to Articles 22 09-14-2011 08:09 AM
Meg UC dusts too fast ... mikek753 Auto Detailing 101 34 11-04-2010 05:01 PM
A situation when a non-forced rotational DA's will correct BETTER than a Flex 3401.... ZEE BEST Auto Detailing 101 60 09-29-2010 07:14 AM
*Review!* Meguiar's New Soft Buff 2.0 Pads!!! 2hotford Product Reviews 19 05-19-2009 07:00 AM
» May 2012
2930 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31 12
» Car Care Brands
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
