Please help me not pull my hair out over this brake dust.
I'm at my wits end here guys. I've got a wheel off my Trailblazer SS trying to give the wheel barrel a good clean and I have hit it with everything shy of napalm and this baked on, imbedded crud won't go away! It's like cockroaches.
I have tried:
-P21S gel letting it sit and scrubbed until my arm was numb
-Iron X same as above
-Wheel clay that was useless
-Griots Garage heavy duty metal polish
-some body shop, rubbing compound that I'm pretty sure has gravel in it
Only thing I have left is polishing soap. But I have this lingering suspension it's going to be to no avail.
And by the way, it's not raised. It can't be felt. It's almost as if it's burned in.
It's it hopeless?
Re: Please help me not pull my hair out over this brake dust.
You could give 0000 steel wool a shot on a small spot.
try acid or if all fails try a steel wool then used metal polish
Hmm. Might try that.
Do you guys think wheel brightener would dent it?
Acid?
wheel brighter just may do it cause its acid...
Wheel brightener should be okay on that bare wheel right? I'm pretty sure the front of these wheels is clear coated so I need to make sure and not get any on the front right?
I did a Z06 about two months ago with wheels with this exact same issue. It was purchased used in Detroit and brought down South. I honestly believe this is road salt damage.
Anyone?
Yes wheel brighter should be ok just wear gloves and a tip apply the wheel brighter to a instead of direct to the wheel that way you have better control of the product, and leave it up there no longer than 5 mins
I'd try to clean with the iron-x again. You say its not raised? Does it seem like its embedded? Maybe its just under the surface of the clearcoat?
Sent from my SAMSUNG-SGH-I777 using AG Online
By mswerb in forum Auto Detailing 101
Last Post: 12-02-2012, 09:02 PM
By checkmate in forum Auto Detailing 101
Last Post: 09-25-2012, 11:37 PM
By CWallace in forum Auto Detailing 101
Last Post: 06-04-2012, 06:51 PM
Last Post: 05-21-2007, 07:16 AM
By Joanie in forum Auto Detailing 101
Last Post: 06-04-2006, 11:40 AM
