Which product to by Meguiars, Menzerna or Duragloss?
I have a patriot blue 2005 Dodge Ram that has quite a few swirls. I would post some photos but it's rather dirty right now. Should I get M105/M205 or some menzerna products? I've also thought about duragloss but I'm not sure if they have anything strong enough to remove my defects. Let me know what you think.
Re: Which product to by Meguiars, Menzerna or Duragloss?
can't go wrong with m105/m205 however menzerna has great polishes as well
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by capnp72
Pics would help. All of the brands you listed make top quality products. M105/M205 is a killer combo that will work great on almost any paint finish. I also have an '05 Ram (graphite) and can tell you that M205 finishes down perfectly on this paint system.
If you want to spend the money I would try some of each. Totally depends on your paint and technique. I use products from all three maufacturers.
save some money---m105/205...really 205 should be all you need. you can increase or decrease the cut but changing the aggressiveness of the pad. another recent poster posted a long, well written explanation. this of course applies to this product applied with a machine. my .02
http://www.autogeekonline.net/forum/...potential.html
If your looking to save some coin Meguiar's twins is hard to beat. Now if you have a bit extra to spend pick up some of the new Menzerna FG400 as well as SF4000 or SF4500.
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by spiralout462
^^^ Agree
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by smack
Exactly the answer I was going to give ^^
Sent from my iPad using Tapatalk HD
+1 on the 105/205 combo as it's darned hard to beat.
OTOH, if you are not used to working with 105, and/or you don't have PLENTY of pads, you might want to look at Megs Ultimate Compound. The cut is almost as good but the workablity, added polishing oils and time that it'll work before having to either clean or change pads is HUGE compared to 105. Plus UC just doesn't clump up like 105 does. (well it doesn't actually clump up itself, but the paint it removes tends to make it look like it's clumping up sometimes) Regardless, M105 is one of the best products out there for a lot of different uses, but the level of cut isn't needed for most situations. Once you get a handle on the 105 however it can be used with softer and softer pads to get to darned near LSP stage. ![Wink](https://www.autogeekonline.net/forum/images/smilies/wink.png)
As for 205, it'll work all day and finishes out really well. Which tells a bit as to how well it's sibling, Ultimate Polish will work out. For added flexibility the UC/UP products are great to have in your arsenal.
I've read that M105/M205 dust a lot more than other products and they aren't the easiest to use? I'm new to this and will be using a PC 7424XP along with some white, orange and blue 5.5" pads. Thanks for all of the advice.
By kevincwelch in forum Auto Detailing 101
Last Post: 08-07-2013, 09:12 AM
By jreblackGT in forum Auto Detailing 101
Last Post: 10-14-2011, 11:18 AM
By rwright in forum New Car Care Products
Last Post: 07-15-2011, 10:45 PM
By Slate G8 GT in forum Auto Detailing 101
Last Post: 04-11-2011, 07:34 PM
By superdigg in forum Auto Detailing 101
Last Post: 08-16-2007, 01:40 PM
26 | 27 | 28 | 29 | 30 | 31 |
