Motorcycle Scratches on New Motorcycle.
My first question is, "How do I remove tiny scratches on my new (metallic black) motorcycle? These are scratches from the dealer wiping down the cycle on the showroom floor.
I've used some swirl remover, (Meguiar's), but now have new scratches going in another direction. I usually do not see this problem when detailing my cars.
Thanks to all,
Jim
Re: Motorcycle Scratches on New Motorcycle.
What are you using to apply swirl x? I would start with less pressure more passes or a combination of less aggressive applicator/polish.
I just recently did a correction on the a vivid black (non metallic) harley and it wasn't hard to add new swirls.
For the machine polishing portion, I used CCS 4" orange, white, gray pads respectively with Opti Compound II, Polish II, and Finish Polish. Worked out great.
For the hand portion, I used the CCS hand applicators in white and red with Polish II. I had planned on only use the white pad, but more often then not I was adding new swirls with the white pad and polish II. So I tried the red finishing pad with some polish II and this removed the swirls without adding any new ones as long as the pressure was kept light.
M
2012 Acura TL Graphite Luster 6MT AWD
2013 Mazda Mazda3 Velocity Red 6MT
Working on clear coats by hand takes more skill than using a DA Polisher.
By hand you have to use very good if not expert technique, the right product and a clean, soft foam applicator pad.
By machine with ANY of the DA's, just use a polishing pad and quality polish and the machine takes care of all the technique for you.
I've taught literally thousands of people how to remove scratches by hand so it can be done but it still will never look as good as the results you can get by using a machine.
I worked for Meguiar's for 11 years and was the Primary Instructor for all their classes at their Corporate Office from 2002 to 2009. I'm very familiar with their polishes so let me see if I can work you through how to remove the scratches by hand.
First, which polish or scratch remover were you using?
Originally Posted by crxman2010
A little more scratching then just dealer wipe down, but cleaned up great.
crxman2010,
Did you remove the scratches by hand or machine?
Also,
Roll Call - What's your real first name?
crxman2010,
Combination, most of the hard work was done with a Griot's 6" with the above listed 4" pads in post #2. There were several areas the machine just couldn't get it done due to the contours and frame so I used hand pads to clean up those areas. A lot of it was just that the contours would stop the pad with any amount pressure so I couldn't get the swirls out. Once the swirls were out by hand, a gray pad on the da with little pressure would keep spinning in those areas so I was able to do most of the bike by machine with finishing polish which definitely helped in terms of beauty.
M
I was typing so fast and then going to a meeting I missed post #2 (sorry)
You described a perfect approach.
Not sure if the OP of this thread owns a machine or is interested in getting one but it would be the best way to remove the scratches and restore a clear, high gloss finish both now and into the future because it's inevitable that there will be future scratches in his Motorcycle and anything else he drives.
That said, as a community I'm confident we can help see him through to success working by hand...
On the topic of Black motorcycles , seeing how the paint looked before I started, reminded why I don't want a black car. Seeing the paint afterwards, kind of makes me want a black car . (just not as my dd...)
M
I was using Woflgang total Swirl Remover. I think I was using too much presuure on the pad 4" Blue. I'll try it again with lighter pressure and the orange 4' pad.
For the hand portion, I used the CCS hand applicators in white and red with Polish II. I had planned on only use the white pad, but more often then not I was adding new swirls with the white pad and polish II. So I tried the red finishing pad with some polish II and this removed the swirls without adding any new ones as long as the pressure was kept light.[/QUOTE]
By jmart24 in forum Motorcycle Care
Last Post: 02-10-2020, 01:24 PM
By dcjredline in forum Show N' Shine
Last Post: 06-06-2015, 08:16 AM
By MshawnBauer in forum Show N' Shine
Last Post: 01-23-2014, 10:51 PM
By colonel in forum Motorcycle Care
Last Post: 09-28-2011, 12:28 AM
By suprachica79 in forum Off-Topic
Last Post: 04-23-2011, 09:09 PM
