845 and a Topper?
Just got my bottle of Collinite 845 and plan on using it today. Has anyone tried to top it with SIGII or LS? Not sure if this will be a waste of time or not. I really want to put down WDGPS first then top it with 845 but only have a sample and I don't think this will cover a four door car.
So what does everyone do with the 845?
Re: 845 and a Topper?
I also have a DGPS sample and was able to put like 3- coats of it on my hatchback!!
You have to apply it really thin. You can do1 panel with like 4-5 drops of DGPS all around an applicator pad.
845 is great as a topcoat to any sealant. and in multiple layers, it forms a great barrier to salt and snow( durability in multiple layers is great too)
Wow three coats on your avatar? I should be good with my Dodge Charger if that's the case.
Was thinking the 845 might take away the wet look from the DGPS. The Charger is inferno red.
^Yup!!
It'll easily do close to 4 coats on your charger!! (just put on thin coats, a little really goes a long way!)
I feel 845 is mainly for those who prefer protection more than the wet(test) look (possible on their paint)
If you are winterizing, then 845 is the way to go!(in Spring, WDGPS topped up with SSII or orange crush would look soaked!)
Do you guys feel using an DA is a lot more wasteful then using the foam pads?
I have some expensive wax that I bought recently and don't want to wasteful by using an DA. I have a gallon of M26 and that I don't care for much, will prob use DA with that. But what do you guys apply expensive wax with? Hands or DA?
I got 4 coats of my WGDGPS sample on my A4. Did it by hand.
I prefer to buy my final step waxes in paste form and apply it by hand. I think the DA is more effective at applying wax thinner, which would cause you to use less product, as long as you don't apply too much to the pad. I just like the gratification of applying an LSP by hand.
2011 Nissan Xterra Pro-4x: Avalanche White
2006 Nissan 350Z Touring 6MT: Redline Red
Originally Posted by sohail99
^Yup!!
Yes winterizing....a little late but car has not seen snow as of yet. Good info as I will wait till spring on the DGPS and go with the 845 now.
I love putting on the LSP with the PC using a LC HT Lo Pro 5.5" crimson pad! As mentioned in other threads, these pads do great at not soaking up product.
By hand no doubt. What wax do you consider expensive and what do you have?
I'm of the exact opposite opinion.
Applying waxes and sealants with a DA polisher and the correct pad allow you to lay down the right amount of product and lay it down evenly.
By using a cross pattern I can work the wax into the paint and achieve the "thin" layer I'm looking for. This not only provide complete coverage but also won't over apply the product only to have it wiped off and discarded.
Every time I hear someone having an issue with Collinite 845 it's because someones applied to too thick and more often than not it was by hand....
All of my liquids and allot of my paste waxes are machine applied......
By vilastrex in forum Auto Detailing 101
Last Post: 04-18-2020, 10:10 AM
By EVOlved in forum Auto Detailing 101
Last Post: 12-15-2014, 03:21 PM
By KBsToy in forum Auto Detailing 101
Last Post: 03-15-2014, 01:49 PM
By sportscarhiatus in forum Auto Detailing 101
Last Post: 04-30-2013, 08:09 AM
By DP 08 GXP in forum Auto Detailing 101
Last Post: 10-23-2012, 07:30 PM
