Not if you use the topical grade (3% (the kind you use on cuts) It hasnt harmed anything I ever used it on but by all means test in an inconspicuious area first
the dog did live, he says hes tried everything to remove the stain. I could try the steamer. I don't want to use anything to take the color out.
hydrogen peroxide will take blood out : I might mention this to the owner, he might try 50/50 mixture with water and try.
GaryD
There is a better way to do it than the way you're doing it.
