Results 1 to 7 of 7
    Aug 2009
    311
    Sealant Bonding?
    About a month ago I put on a sealant that AG does not carry. I have used Optimum car wax as well as Meguiars Quick wax on top of it. If I am going to apply another sealant (either Poor Boys EX-P or DP Poli Coat) do I need to first polish to remove the spray waxes or will either of these sealants bond to the car as is?
    Thanks
    Super Member Dubbin1's Avatar
    May 2009
    3,845
    Re: Sealant Bonding?
    Already answered on another forum
    Super Member Rsurfer's Avatar
    Jan 2007
    14,110
    Quote Originally Posted by RandyD View Post
    Thanks
    If you don't need to polish to remove marring, just use a pai
    nt cleaner or do an IPA wipe down. Not a good idea to put a sealant over a wax.
    Aug 2009
    311
    I just noticed it said the following on the Autogeek website regarding DP Poli-coat Paint sealant - "With most paint sealants, it is recommended that you use a pre-wax cleaner first to prep the paint for the sealant. This step promotes bonding and improves the clarity of the shine. But what if you could achieve the same high bonding and clarity without a second step? That’s what you get with DP Poli-Coat Paint Sealant".
    Anyone ever try this without polishing or removing carnauba wax first?
    Thanks
    Jun 2008
    Lawrence
    589
    Well my first question is, do you need another coat of sealant?
    Generally I have found if you mix things too much you will run into issues such as streaking/drying problems/or decrease in longevity.
    Super Member loudog2's Avatar
    Aug 2008
    St. Charles, IL.
    2,880
    Quote Originally Posted by aerogt01 View Post
    A second coat is usually good to make sure you get any spots you might have missed. As for coats, someone did a experiment and showed that there is no reason for more than 2 coats. The second coat of carnuba added protection, but the third took some away.
    Super Member truckbutt's Avatar
    Oct 2010
    NYC
    907
    Meguiars recommends two thin coats of its M21 ver 2.0 sealant, mostly I believe to catch any areas you may have missed on your first pass.
    Best Regards,
    Scott Muscle Car Detailing - Mod and Shine
    Detailing supplies aren't cheap, but they're a lot cheaper then therapy
  1. Miscible and Immiscible - Wax and Paint Sealant Bonding
    Last Post: 08-03-2020, 09:14 AM
  2. Sealant bonding
    By frankprozzoly in forum Auto Detailing 101
    Last Post: 07-03-2014, 08:40 AM
  3. Sealant bonding question
    By Nate3420 in forum Auto Detailing 101
    Last Post: 06-12-2013, 06:17 PM
  4. Question on sealant bonding
    By RPPM in forum Auto Detailing 101
    Last Post: 02-16-2012, 04:56 PM
  5. Will glaze affect sealant bonding
    By LegacyGT in forum Auto Detailing 101
    Last Post: 11-13-2010, 02:19 PM
