Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Jul 2017
    310
    Another coating high spot question
    Hey guys,
    I found some threads on this, but many different answers. I just coated my ride with Wolfgang PROFI, and I have some high spots. Two of them I tried to fix, but I didn't get it right.
    Is there a good method to polish only a specific area and reapply? Or do I need to do the whole panels? The worst offender is the rear bumper, which is the trickiest part.
    If I mask off the area, polish, then reapply with some overlap, should I be able to clean this up?
    On a brighter note, there's this:
    Thanks all
    John
    Attached Thumbnails Attached Thumbnails Another coating high spot question-img_2507-jpg   Another coating high spot question-img_2508-jpg   Another coating high spot question-img_2509-jpg
    Mar 2017
    Southeastern PA
    2,480
    Re: Another coating high spot question
    I’ve never been able to blend it well, always had to polish and coat the entire panel again to achieve satisfactory results.
    Bruno Soares
  3. Thanks jdgamble thanked for this post
    Likes SNP209, PaulMys, Eric7810 liked this post
  4. #3
    Dec 2018
    7,205
    Yeah same here usually whole panel. If you have enough left I would try to spot blend it. Maybe your coating will react differently.
    If it doesn’t look right then redo whole panel.
  5. Thanks jdgamble thanked for this post
    Likes PaulMys liked this post
  6. #4
    Aug 2013
    St Louis metro (Illinois)
    5,829
    Location of the high spot and the color of the paint have a lot to do with how easily you can correct the spot.
    I found on dark colors in a highly visible spot like a door, hood or roof, it took a re-do of the whole panel to make it look right. On an area like the front facia, rocker panels or rear bumpers with a light color you might be able to spot correct.
  7. #5
    Jul 2017
    310
    It's yellow and apparently very forgiving, cuz I kinda blew it. I will probably try the easy approach first.
    Thanks for the feedback.
  8. #6
    Super Member Danube's Avatar
    Jan 2012
    Australia
    1,185
    Quote Originally Posted by jdgamble View Post
    Hey guys,
    Thanks all
    John
    Did you use too much product .... what caused the high spots ?!
    Or you left the product for too long before wiping it off ?
    Flex 3401 & PE14
  9. #7
    Super Member Eric7810's Avatar
    Mar 2019
    330
    If it’s up to five hours later that I see the spot I can dab some coating on my applicator and basically polish it out.
    If it’s the next morning that’s when trouble starts.
  10. Likes PaulMys liked this post
  11. #8
    Jul 2017
    310
    Quote Originally Posted by Danube View Post
    It flashed super quick on the bumper, and I felt like I had been wiping too hard and removing too much coating previously. So I probably didn’t wipe those spots hard enough. I may have used too much too. On one section, I applied a second time because I felt like it came off too easy.
    It was my first time coating, so learning experience. Honestly 99% of the population would never notice. But I’m in the 1%, as we all are. Haha.
    Car looks pretty good. But really no better than PNS+sovereign.
  12. #9
    Jan 2012
    Australia
    1,185
    I take - it the difference between a top shelf wax and ceramic coating is mostly in durability of the protection, not the way it looks (as if something can look better than 2 layers of 845 .. in my view at least .. )
    Flex 3401 & PE14
  13. Likes PaulMys liked this post
  14. #10
    Mar 2019
    330
    One main difference is that ceramic coating isn’t coming off. You can strip wax relatively easy.
  1. Replies: 12
    Last Post: 09-19-2022, 10:04 AM
  2. How to remove a Ceramic Paint Coating High Spot by Mike Phillips
    Last Post: 10-12-2020, 09:49 PM
  3. CQUK High Spot Removal on Alpine White BMW
    By fotomatt1 in forum Auto Detailing 101
    Last Post: 05-17-2016, 10:31 PM
  4. OC 2.0 Maintenance and high spot question
    By Quattro3.2 in forum Ask your detailing questions!
    Last Post: 12-14-2013, 08:59 AM
  5. Opti-Coat high spot fix?
    By coredump4 in forum Ask your detailing questions!
    Last Post: 03-27-2013, 04:28 PM
