Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    Super Member 98CayenneTA's Avatar
    Aug 2020
    Minnesota
    593
    Re: Best way to clean around emblems
    Quote Originally Posted by Bill D View Post
    How are folks choosing to debadge? By using floss? Fishing line? The last time I debadged was over ten years ago and I used plenty of floss.
    I use fishing line then a 3m rubber wheel.
    Ripping through your mind like a hurricane full of novocaine
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,230
    Quote Originally Posted by 98CayenneTA View Post
    This^^^
  3. #13
    May 2011
    1,205
    If you are not debadging, I recommend a soft brush, and a water spot remover if there is a lot of build up. In some instances, when I have a client that uses the automatic car wash alot, those areas are never cleaned right. Only way to get them clean without debadging
  4. #14
    Mar 2011
    PA
    5,802
    2018 Colorado ZR2
  5. #15
    Regular Member crg001's Avatar
    Oct 2020
    Redlands CA
    171
    Quote Originally Posted by Billy Baldone View Post
    Yup, this is the way! I use 3D Eraser Gel with a detail factory ultra soft brush. Squirt some gel directly onto the brush, and agitate through every crevice. The acidic products work especially well in this case, as often times the gunk in between the badges is all hard water and mineral deposits that regular car soap and alkaline degreasers won't touch.
    Colin Lang
    @DimensionalShine <- My Detailing IG Page
  6. #16
    Super Member 2wookies's Avatar
    Jul 2015
    367
    MAN!!! I had a bad day with that wheel few years back, customer told me that he was washing his car and one of his emblems fell off the fender when his wash mitt hit it. So he asked me to removed the rest prior to a correction and coating, I also had one of them fall off. So removed both fenders emblems and then grabbed my wheel, as I had dozens of other times, and started removing the adhesive….then the paint fell off! LITERALLY fell off when the wheel hit it, had a nice tasty looking paint chip on my garage floor.
    Customer wasn’t mad as it was obviously a bad paint job and got it fixed, but that was a bad day for sure.
  7. Likes Eric7810 liked this post
  8. #17
    Super Member JDGolden's Avatar
    Mar 2013
    Michigan
    1,516
    I've debadged a lot of vehicles in my day but I think I agree with the OP. I'd leave those lol.
    2017 Jeep Wrangler Unlimited Rubicon
    1999 Camaro Z28
  9. Thanks dieselfan1 thanked for this post
  10. #18
    Super Member Azure's Avatar
    May 2013
    Indianapolis, IN
    401
    Yeah a boars hair or detail or a detail factory ultra soft brush if paint is soft. I use to do in snow foam stage but now do as Opie does and just use bucket wash soap.
    I still do mine in the snow foam stage. Did you notice some negatives doing it this way that made you switch it up?
  11. #19
    Aug 2013
    St Louis metro (Illinois)
    5,827
    Quote Originally Posted by jlindyman View Post
    De-badge
    Quote Originally Posted by MisterSnoop View Post
    I used a hair dryer to heat it up. Then I used fishing line, which mostly separated the badge from the adhesive. The foam adhesive was easy to roll up/off of the car. Followed up with goo gone.
    This.
    One of the first thing I do to my cars regardless of trim or price is to start removing badges. I find them unneeded and disrupt the design of the car. not to mention are a royal pain to clean/polish around. I'd de-badge the automaker badge too if I could, but it's often not an option because they are recessed and held on with rivets/clips of some sort that leave holes.
  12. #20
    Dec 2018
    7,198
    Quote Originally Posted by Azure View Post
    I figure the foam stage is to remove surface debris and soften it up. The PW to remove and don’t want to rub in whatever foam is breaking down. I put black 5.0 badges to replace the crome one’s and noticed swirls when i use to brush them in foam stage
    I foam the car dry as I figure it won’t won’t get watered down and penetrate better if foam goes on dry car.
  13. Thanks Azure thanked for this post
    Likes chilly, Azure liked this post
  1. What to do around trunk emblems
    By redzone1 in forum GYEON Car Care Products
    Last Post: 12-06-2018, 01:58 PM
  2. How Do You Protect Emblems?
    By William D. in forum Auto Detailing 101
    Last Post: 02-17-2013, 03:15 AM
  3. Detailing around emblems??
    By Success in forum Auto Detailing 101
    Last Post: 12-03-2012, 04:09 AM
  4. Car emblems
    By oldgeek in forum Auto Detailing 101
    Last Post: 08-23-2012, 03:14 PM
  5. polishing around emblems??
    By mjc189 in forum Auto Detailing 101
    Last Post: 11-28-2011, 08:29 PM
