Storing rinseless between washes
Wondering if anyone has any suggestions for a container to use/store rinseless wash.
So far I've just been using 5 gallon buckets with Gamma seal lids, but since I most often just use the multi-towel/mitt approach, I usually only mix a gallon or two at a time. I store all my detailing stuff in the basement to keep it away from freezing/heat, and I'd like to cut down on having a stack of 5 gallon buckets down there.
I'd like to find something in the 2-2.5 gallon range that seals well to prevent spills/spoilage (I use distilled water, but every little bit helps).
I know the easy answer is to just pour whatever's left back in a gallon jug, but it'd be nice to just be able to grab and go.
What are folks using?
Re: Storing rinseless between washes
Gamma seal makes lids for 2 gallon buckets.
I have a bunch of 3.5gl buckets (often used for pool supplies) and they use the same lid as 5gl buckets.
How about some of those large, cat liter containers with screw on caps? Those seem to be larger than a gallon IIRC, I've used them for this use before
2022 Elantra N Cyber Gray
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png)
Originally Posted by
howardm4
This.^
They make smaller buckets.
oneheadlite
I use 5 gals but if you want smaller just hit up a paint store and use their 1 or 2 gal buckets with lids. they should work fine. I have several from Home Depot that I use for various things. Cheap and decent quality.
Check these out:
Hudson Exchange 2.5 Gallon UN Hedpak HDPE Container With 63mm Caps, Pack of 2 | eBay
They're a big step up from cat litter containers (Which will eventually leak all over your stuff. Been there.). 2 1/2 gallon size and basically the same size as cat litter containers.
One thing to consider is 'will the GritGuard fit'. I *know* that the std. GG will fit 5 & 3.5gl but I can't say that about the small ones.
Also, on the 3.5gl, the GG raises the minimum water level to 1gl (right to the top of the GG).
I just got a Gamma seal lid because of this thread. Any idea how long I can store rinseless solution before it gets funky? I'm gonna go get 3 gallons of distilled water.
Thanks for all the input!
Not too worried about the grit guard, the idea is to keep the bucket/container mixed and ready to go for the “multi media” approach- either a stack of towels dunked in there, or very likely Eldo’s multi-mitt tactic. Whatever the media it wouldn’t go back to the bucket.
jdgamble
Using distilled water and keeping the mix inside when not in use, it’s a pretty long while. I’ve got a bucket each of N-914 and the Griot’s rinseless that are over a month old with no signs of funk/separating.
