Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    May 2015
    75
    After wash drying technique?
    Hey guys I am looking for some advice on drying my car after washing. Typically I use a leaf blower to dry the majority of it and dry whats left over with a waffle weave. I have had issues with some soap residue that requires me to add slight pressure while drying some areas of my car. Since my car is black I have noticed slight marring from the drying process. I've head about using a quick detailer to help aide in the process.
    I'm looking to purchase something along the lines of a quick detailer to help aide in the drying process. What do you guys think? What do you guys use?
    Thanks!
    Super Member fly07sti's Avatar
    Sep 2013
    SF Bay Area, Cali
    2,939
    Re: After wash drying technique?
    Your process sounds ok. What towel are you using and what soap are you using? Yes QD can help with reducing marring IMO.
  3. Likes RBATTLE10 liked this post
  4. #3
    Jun 2017
    126
    Blow off water and follow up with a microfiber and some detail spray. Never understood the giant waffle weave fans unless of course you don't have access to a quality blower.
    Sent from my SM-G935V using Tapatalk
  5. #4
    May 2015
    75
    Quote Originally Posted by fly07sti View Post
    I am using the chemical guys waffle weave yellow towel. For some reason its lost its softness and feels rough on the paint. I am using Adams soap. What's your personal recommendation on megs quick detailer?
  6. #5
    May 2015
    75
    Quote Originally Posted by Cleankat View Post
    I'm looking into getting a microfiber drying towel. What quick detailer do you recommend?
  7. #6
    Super Member luckydawg's Avatar
    Jan 2016
    1,117
    The less things that come in contact with your cars finish- the less chance of marring / beauty marks, thats why I blow off all the water I can.
    Using a high quality towel like the geyon silk and a QD where needed is the way to go i believe. Good luck to you.
  8. #7
    May 2015
    75
    Quote Originally Posted by luckydawg View Post
    What QD do you use? Thanks!
  9. #8
    Jan 2016
    1,117
    Griots speed shine- I like their products / line and its the least expensive of the two that they offer- but most any will work-- you just need that lube when your drying.
  10. #9
    Aug 2013
    St Louis metro (Illinois)
    5,856
    Are you seeing soap residue or are they just water spots?
    If you're seeing actual soap residue, rinsing more and earlier will go a long way to help with that. Also you can reduce the amount of soap you're using in the bucket to help it rinse off cleaner. Yet another option would be to change the soap you're using to something better that rinses off easier. I've used some horrible, cheap car shampoo in the past that would rarely rinse off cleanly.
    As the owner of a black car, I rarely dry without spraying a little QD on the towel and/or the surface. This not only helps prevent marring, but it also helps to remove any stray water spots that formed after I flood rinse.
  11. Likes DogRescuer, tofuproductions liked this post
  12. #10
    Nov 2015
    Los Angeles, California
    13,851
    Quote Originally Posted by Ruben12 View Post
    You already have a microfiber drying towel. That’s what the waffle weave is made of.
  13. Thanks sorehands thanked for this post
    Likes DogRescuer liked this post
  1. Replies: 5
    Last Post: 11-14-2018, 03:17 PM
  2. Drying technique
    By muscleman in forum Auto Detailing 101
    Last Post: 04-05-2014, 04:01 AM
  3. Critique my drying technique
    By GreatAvalon in forum Auto Detailing 101
    Last Post: 03-29-2014, 11:26 AM
  4. Help with drying technique
    By LuisA in forum Auto Detailing 101
    Last Post: 04-18-2010, 08:28 PM
  5. best drying technique
    By fech in forum Auto Detailing 101
    Last Post: 04-02-2008, 01:08 AM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
