Overspray or heavy fallout on everything best options for removal?
A little backstory.
My vehicle is my daily driver. It normally gets a quick 2 bucket wash every couple of weeks with spray on wax/detailer as i dry. A collinite 845 wax every 2 or 3 washes and a full strip down clay and DA polish a couple times a year. I just did the long process (couple hours for me) about a month ago and it looked fantastic.
about 2 weeks ago... i noticed gold specks all over the car after what should have been a quick wash. I didn't have time to take a closer look or do anything about it and figured it was likely pollen. Rained the following couple of days and listening to the wipers scrape across the window was driving me nuts. Washed it down again at the next opportunity and all the horizontal surfaces are heavily contaminated and the vertical ones are not much better off.
Rubber around windows.. gold flake.
metal on widow wipers... gold flake.
Clear plastic over lights.... you get the idea.
I feel like every exterior part will have to be replaced or cleaned before i am happy with appearance again.
I do not know exactly where all this gold crap came from. To the best of my knowledge, I haven't been around any painting but I do work at an industrial facility (steelmill) and have been asking around if anyone else has the same symptoms. Lots of early clearcoat failure on vehicles here but no one (who cleans their vehicle semi-reguarly) has noticed sparkly gold dusting.
I have already tried my OTC maguires clay on a section of hood and a window. That did a decent job but still some gold flakes are left behind (and it takes forever!) At this point I called around for some quotes from detailers and car wash places just to see how much it would cost to have someone else spend their time doing a professional job. I was getting responses of $250-300 to clay and remove overspray for my small crossover (sapphire black nissan Juke)
Figured i would give something else a try myself 1st. Picked up a Mothers speed clay 2.0 'eraser' to see how it does. It was actually after dark before i got the first chance to use it and I was working by sound. when it stopped sounding like i was sanding a section I would move on to the next. This item was much, much faster than using the actual clay bar had been. It took lots of contamination off the car and did a great job on the windows but there is still more to remove. I have made multiple passes with the speed bar ( in the daytime as well) and am not getting much more off with it.
so back to the question in the title...
do i need a special type of clay or nanoskin mitt or is there a some pad / product combo I can use on my Harbor Freight DA poilisher or is there something else I should be using?
