Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Junior Member CarefulCleaner's Avatar
    Nov 2016
    45
    How to fix disastrous touch-up paint job
    I asked for some paint from my dealer, so I could touch-up my car manually, but they "took away the trouble" and did it for me---with disastrous results:
    How to fix disastrous touch-up paint job-o11xdk7-jpg
    So...I've got an assortment of #1000-#3000 grit sand paper and additional touch-up paint from my dealer.
    How can I make the best of this situation now? Should I paint over areas where my dealer missed, let the paint dry, then wet sand the area, until it's level with the surrounding area, then compound/polish/wax? In what order of grit should I wet sand the touch-up paint? How many layers of touch-up paint do I need?
    It seems like I can also try to compound some of the other scratches that were not treated with the touch-up paint...
    Thanks in advance for any help.
    P.S. This is a 2004 Honda CR-V (single stage paint, I think, since compounding rubs off some white paint onto my applicator pads).
    Aug 2010
    New Jersey
    15,315
    Re: How to fix disastrous touch-up paint job
    If that's factory paint, you should be able to wipe off/out the touchup with lacquer thinner, if that helps you.
    Disclaimer: I haven't tried this with single-stage paint, although I believe any single-stage from that era would still be a catalyzed urethane paint and therefore chemical resistant.
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,450
    Quote Originally Posted by CarefulCleaner View Post
    If THEY did it and you didn't approve or aren't happy, I'd make them fix it. IMO I would have them respray that bumper entirely.
    2023
    Sep 2015
    2,174
    Quote Originally Posted by pdqgp View Post
    what he said
    Super Member Rsurfer's Avatar
    Jan 2007
    14,111
    Is this your Honda Dealer or a Dealer from which you bought the car? In any event, the car is 12 years old.
    Jan 2007
    14,111
    [QUOTE=CarefulCleaner;1439947]I asked for some paint from my dealer, so I could touch-up my car manually, but they "took away the trouble" and did it for me---with disastrous results:
    How can I make the best of this situation now? Should I paint over areas where my dealer missed,Yes let the paint dry,Yes[/COLOR] then wet sand the area, Yesuntil it's level with the surrounding area,Yes then compound/polish/wax?Yes In what order of grit should I wet sand the touch-up paint?Start with 1000, 1500 and finish with 3000 How many layers of touch-up paint do I need?This is where most fail..do light coats and let dry for at least 24 hrs between coats. Build up until slightly higher than the surrounding area.
    It seems like I can also try to compound some of the other scratches that were not treated with the touch-up paint...If you can feel the scratches with your finger nail, the scratch is too deep to be buffed out and needs touch up paint.
    P.S. This is a 2004 Honda CR-V (single stage paint, I think, since compounding rubs off some white paint onto my applicator pads).[/QUOTE
    Nov 2016
    45
    This is the work of *the* Honda Dealer. And yes, it's an old car, so I wanted to avoid a confrontation/claim (despite my misgivings), thinking I might as well take this opportunity to learn how to do the job right myself.
    Thanks rsurfer, I will give it a try. Just still a little uncertain about when to stop layering paint and whether or not I should, as Setec Astronomy suggests, remove the paint first and start all over again, or layer upon the (factory) paint that's already been put on.
    Super Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    2,002
    Dr. Colorchip should be able to give you a better color match. I would try to remove the touch up paint applied by the dealer, then apply new touch up paint that matches, then sand, buff, seal as necessary.
    Super Member rmagnus's Avatar
    May 2011
    SoCal
    1,446
    Its an easy fix if you have the right tools. You are going to at least do a blended fade and repaint the damaged area. I would never let that dealer touch the car again. There are many touchup paint suppliers that can provide you the paint.
    A touchup automotive paint gun is best but there are many reallly good rattle can Arneson cans out there today. Feather sand the ares back mask and shoot it with thin layers building it up. 4-48 hours later cut and buff the area then wax it about 4-5 weeks later.
    rsurfer gave you sone sound advise above.
    Semper Fi
    Ralph
  10. #10
    Feb 2016
    91
    This . I would be pissed if they did that to me
  1. Replies: 32
    Last Post: 12-23-2016, 09:38 AM
  2. Disastrous results.
    By 2old2change in forum Ask your detailing questions!
    Last Post: 04-01-2015, 09:32 AM
  3. Touch up paint?
    By Sunder92 in forum Auto Detailing 101
    Last Post: 03-29-2013, 07:52 AM
  4. removing spot gloss touch up paint to expose original paint?
    By slacknh in forum Auto Detailing 101
    Last Post: 09-16-2012, 11:37 AM
  5. A question about 3 stage paint and touch up paint.
    By Silverstone in forum Auto Detailing 101
    Last Post: 08-27-2010, 06:59 PM
