Results 1 to 8 of 8
    Super Member sasson's Avatar
    Jan 2013
    335
    Sanding, Fresh Paint, Factory Paint ? =/ help please.
    I see those many threads saying that sanding is only common on "Fresh Paint".
    And people usually don't sand "Factory Paint".
    I am really sorry but I am not an expert... doesn't every new car get "Factory Painted" ?
    Lets say that my friend bought a car recently and someone made a small scratch, can't I sand hes car ?
    I have a paint gauge if that's the problem...
    Another question I wanted to ask, is can I hand sand a car without a Polisher ( without a sanding disk ) ?
    I have a Flex 3401, And I don't really want to buy another machine right now =/...
    I bought all megs sanding papers ( and that black sponge ), 1200, 1500, 2000, 2500, 3000....
    Could I just use them all by hand ? and get awesome results ?
    And another Pretty important question... How much paint does sanding remove compared to a Compound and Finishing polish ? ( I know that compound + finshing is about 4 Microns removed ? ) Any Estimate ?
    Everyday..... learning something new... Love this..
    Sasson - White Subaru Brz 2013
    Super Member Evan.J's Avatar
    Sep 2012
    Pittsburgh, PA
    4,915
    Re: Sanding, Fresh Paint, Factory Paint ? =/ help please.
    When people refer to fresh paint, most of the time they are talking about a body shop repaint or a custom paint job. With a factory paint job usually these clear coats are too thin and you can run the risk of burning throgh or sanding through the paint (clear coat).
    Its hard to judge the amount of paint thats removed by wet sanding unless you have a PTG handy.
    Here is a write up by mike that you will want to read through:
    http://www.autogeekonline.net/forum/...mpsanding.html
    Official Detailing Team Member of Air Force One
    Flex 3401 / Flex PE8 / Rupes 21 / G110v2 / GG6" / Rupes 75E / GG3"
    Click and Like my Facebook Page
    Jan 2013
    335
    Quote Originally Posted by Thoryamaha919 View Post
    Thank you, Great info =)
    Sep 2012
    Pittsburgh, PA
    4,915
    This article is the one I wrote to do my best to clear up all the confusion around the topic of wetsanding.
    It fully explains the difference between a new car and a new paint job. These are usually VERY different types of paints to work on.
    Has a lot to do with "planning" and I cover that in the article.
    Jan 2013
    335
    So would you say that you should never Sand a car that has Factory paint? even if you have a paint gauge and see that the paint has enough clear coat ?
    Sep 2012
    Pittsburgh, PA
    4,915
    Quote Originally Posted by sasson View Post
    Well I would think that if Mike says there is too much risk involved woth sanding a factory clear then I wouldn't. A PTG is only going to give you an idea of what your working with from the panel through the clear coat. SO its not really telling you the thickness of the clear but of all the coats (primer, base, color, and clear). If you sand through the clear then you wil have to get the area repainted and that will make for some expensive fixes.
    Jan 2013
    335
    Dang it, I hope there is enough cars with fresh paint lol...
    I don't really think there are much here in my country...
  1. Wetsanding - Fresh Paint vs Factory Paint
    Last Post: 10-26-2016, 07:20 AM
  2. What are your thoughts on wet sanding factory paint?
    By z06meister in forum Wet-Sanding, Cutting & Buffing
    Last Post: 11-09-2015, 05:19 PM
  3. Sanding factory paint down to primer with 7424XP?
    By BrutalGT in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 08-27-2014, 01:59 AM
  4. Factory fresh paint
    By Maldini in forum Auto Detailing 101
    Last Post: 04-20-2011, 01:38 PM
  5. Factory oil-sanding of paint?
    By ronniejay in forum Ask your detailing questions!
    Last Post: 11-25-2009, 09:35 PM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
