Finishing pad soaking up product...
I have a Lake Country black finishing pad that I use for my Chemical Guys glaze and man... does it suck product up like a vacuum. Part of it is my fault because I did use quite a bit of the glaze, but the pad itself seems to soak it up so much that it almost forces me to use more product. Is there a way to remedy this or something? If I add an adequate amount of product, it'll eventually seem to go dry, thus needing more product. But it's like the more I add, the more the pad soaks up. I rinsed out the finishing pad when I was done glazing my car and I swear I squeezed out about 2 to 4 more nickel-sized amounts. I put it back in the bottle, lol.
So is this all operator error or does my LC pad just soak up too much?
Re: Finishing pad soaking up product...
I found the blue to soak up a little but not the black. I guess it could be operator, or product, or a combo. I guess thats why Hydrotechs are so popular around here.
That's one of the reasons I don't use a machine for glazes and sealants - IMHO too much gets wasted in the pad. I'm pretty impressed in how fast you can spread out liquids with a Polishin' Pal and a 3.5" pad.
You may want to try Hydrotech pads. Closed cell structure should keep more product on the surface - or that's the theory.
I have the trio of Hydrotech pads, but I use the red one for my Menzerna sealant and I didn't want to put the glaze on my dedicated sealant pad. Maybe I'll just order another red HT pad. It soaks up a little bit of the sealant, but nowhere near as much.
The only wax I can spread out easily by hand is carnauba wax. With sealants, they're so sticky and stronger, my hand start cramping something terrible. Once I started waxing/sealing with the PC... I quickly became spoiled, lol.
that's one of the reasons i don't use a machine for glazes and sealants - imho too much gets wasted in the pad. I'm pretty impressed in how fast you can spread out liquids with a polishin' pal and a 3.5" pad.
absolutely!
What I do is on the last couple of panels, I stop adding product and just squish the pad down on the panel and that releases enough to finish the car :-)
Yeah, I actually noticed that once before. I probably could have waxed my car halfway around again with what was left in the pad, lol.
And I see some others don't as well.
OTOH Megs 21 for instance says to use a machine, even gives speeds for a rotary. I've done it without but like it a lot better with. It's not the soaking up that kills me, it's trying to wash the darned thing!
By ToddA in forum Product Reviews
Last Post: 04-11-2020, 03:29 PM
By thill381 in forum Ask your detailing questions!
Last Post: 09-18-2018, 07:51 PM
By fellipe in forum Auto Detailing 101
Last Post: 08-31-2014, 07:54 PM
By anson89 in forum Auto Detailing 101
Last Post: 12-17-2009, 11:35 PM
By Totoland Mach in forum New Car Care Products
Last Post: 05-01-2006, 12:43 PM
