Re: Paint abrasion, horrible touch up job
Ugh...
I feel your paint - Bill Clinton
I feel your paint... Mike Phillips
If you lived close by I would be more than willing to help you with it...
Man, if only.
Although maybe that'll happen one day. My wife is a big Disney World fan, and to my surprise, would be happy to have me go to your boot camp the next time we make a trip to Florida. That could happen sometime next year (won't work this year since our anniversary is just a few days prior to your Sept dates. Already got a trip planned).
Anyways, I might be giving this a try today. Sandpaper has been soaking for a while now. Going to re-read some things and when my nerves are solid, I'll make a go at it.
You may be able to check around the forum and see if there are any detailers in your area who wetsand. You may come out cheaper just doing it that way once you consider the time and materials used.
Originally Posted by brentech
Man, if only.
Remember, what you're trying to accomplish is to sand down as much of the touch up paint as possible WITHOUT damaging or removing any of the surrounding paint.
Get some 2" wide painters tape, or 1" will work, and tape off the area around the affected area in order to protect it. Tape out approximately 3 inches either side of the area to be sanded.
Because the area is wide open you might ant to start off with your sandpaper wrapped around a fairly rigid or stiff block to concentrate your efforts on the high points only. This will tend to remove most of the unwanted or extra paint allowing you a much easier time and fixing this.
If you're careful and take your time this should come out pretty nice!
Perfect advice.
You can also cut the sandpaper into small pieces and use your finger to lightly sand the area.
And to be extra careful, work the sanding marks out using either M105 or Ultimate Compound using a small piece of terry cloth with your fingers.
Considering the way it looks right now I seriously doubt wet-sanding it will make the situation worse. If you focus (as Mike said) the sanding on the touch-up paint'ed area itself; even levelling it will make it look 200% better.
From my perspective your approach needed some minor adjustments but overall I believe once you have the spot leveled out and polished it will be much better. You just need to move from step to step slowly. Lack of patience will show very quickly.
Lastly, what cannot be assessed right now is how the touch-up paint will blend with the rest of the car. I wouldn't worry about that though since this approach is the cheapest approach to fix the problem.
Okay, here it is. I think it went pretty well for the most part. Still can be seen from the right angle, but is mostly hidden. Yeah, it's always going to bug me to a degree, but maybe in the future with some different tools at my disposal (just a PC7424XP at the moment) I'll be able to really flatten it out. While I'm trying to keep the car as good as possible, it's not like it's a show car.
Here we are, just taped around it as you last saw it:
Wet sanded to where I felt safe:
Used Meg's 105 on tangerine pad:
More work was still needed towards the top and left side, tiny bit more wet-sanding, then M105 a second time:
Meg's 205 used on a white pad:
A picture using a photography daylight constant as a sun, if not done from the right angle, the metallic in the paint makes it almost impossible to notice:
Opened garage for real lighting and took a few steps back:
Last picture here is centered on the abrasion:
So, while its still there in a bit, the paint did fill with the color. If viewed from the correct angle, you can see it, but otherwise it's not a total eyesore as it was.
I still have yet to re-apply some WG DGPS to it.
wow fantastic !!!!
This forum has some amazing advice !
That looks excellent. no joke.
I had a GTI and I know what you mean about those touchup pens. They are the worst in the industry.
Nextime get the DR.Colorchip road rash kit. Its so easy to use. I've used it about 10 times on the front end of my S4.
Thanks. Was very nervous about going at it with sandpaper, but something had to be done.
And yea, I think a kit would better serve me in the future.
By apsol in forum Auto Detailing 101
Last Post: 10-19-2018, 08:41 AM
By Clifford in forum Auto Detailing 101
Last Post: 02-24-2015, 09:55 AM
By slayer of souls in forum Ask your detailing questions!
Last Post: 05-14-2014, 08:32 AM
By slacknh in forum Auto Detailing 101
Last Post: 09-16-2012, 11:37 AM
By Mark Preus in forum Off-Topic
Last Post: 02-22-2010, 09:20 AM
